Old 01-18-2012, 11:48 PM
Seanyjonny Seanyjonny is offline
Battery/Starting problems
Was at the gym, went to turn key and the power died, figured it was the NSS because ive had this problem before, mess with the stick a little bit and power will come back. Was having a harder time this time, so got a buddy to jump me and it got power and started up. On the way home every time id slow down to a stop the power would drain and the car would almost die. As i was pulling in my drive way, luckily, it died and i coasted in. Figured it was the battery so i switched mine with my brothers. Was putting on the connectors and was having a hard time because sparks kept hitting me in the arm and id flinch and pull it back off, bolts wouldnt tighten, etc. FINALLY got a good connection and the wipers and lights stayed on and wouldnt turn off (even if the key was out of the car). Tried to start it and just a sustained whirl or a spinning, almost like a vacuum cleaner. Any ideas? All help is appreciated!
Old 02-08-2012, 07:23 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Battery/Starting problems
First thing I'd do would be to check the battery cables for corrosion. Posts on here have shown corrosion up to 8" from the battery.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
My Fiat Punto Car Wont Start Ilhanx64 Punto | Idea | Punto Grande 2 10-21-2010 06:14 AM
99 Jeep Grand Cherokee battery change issue. brutass Grand Cherokee | Grand Cherokee SRT8 3 01-27-2010 09:21 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
Battery/Starting Problem---Need Help gregc '88 - '91 Civic | CRX | Wagon | Shuttlee 2 05-26-2004 05:28 AM
