Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-16-2012, 02:02 PM
sixwongs sixwongs is offline
1999 Saturn SL2 Noise from right side wheelwheel to right
Started to hear noise from passenger side front wheel at higher speeds and will disappear when turning wheel to right.
From what I have been reading this sounds like it the wheel bearing.
Is this a easy repair or is more work than it sounds.
Autozone shows wheel bearing and hub as separate pieces.
when removing the parts from the car do they come out as assembly or in parts
Old 01-16-2012, 04:58 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 1999 Saturn SL2 Noise from right side wheelwheel to right
Your wheel bearing is pressed into the knuckle. The knuckle will need to be removed, the hub pressed out, then the bearing pressed out. One of the bearing races will be stuck on the hub and will need to be removed. (don't forget to remove the retainer for the bearing!)Bottom line, if you don't have a press, pull the knuckle and take the parts to a machine shop and have them do the pressing.
1999 Saturn SL2 Cranks but Won't Start davmaj2 SC/SL/SW 8 08-31-2010 08:41 PM
1999 Saturn SL2 Rear Door Panel removal-frozen torque screws mgoldman9484 SC/SL/SW 3 01-20-2009 02:30 PM
1999 Saturn SL2 Crankshaft Position Sensor Location 95GMCJimmySLE SC/SL/SW 3 01-28-2008 09:16 AM
1991 - grinding noise from front when turning right dickboren '88 - '92 5 10-28-2004 11:50 AM
1999 Saturn SL2 Instrument Cluster Removal? AZ_home SC/SL/SW 0 10-18-2004 12:39 PM
