Old 01-16-2012, 11:09 AM
mbogaski mbogaski is offline
2004 Sunfire wont shift into gear
Hello,
My daughter has a Sunfire that starts, but you can not shift into gear. The shifter will move but not engage the transmission. Where do I start looking to figure out whats wrong. She drove the car yesterday with no issue. Help
Old 01-16-2012, 03:17 PM
Tech II Tech II is offline
Re: 2004 Sunfire wont shift into gear
Lift the hood......have someone move shifter....watch the shifter cable where it attaches to the lever on the tranny......does it move?
The Following User Says Thank You to Tech II For This Useful Post:
mbogaski (01-16-2012)
Old 01-16-2012, 03:43 PM
Thanks for the reply...It appears the cable is disconnected from the tranny. Just has the black ball at the end
Old 01-16-2012, 09:13 PM
Just position the end of the cable over the ball of the lever.....then using a pair of pliers, squeeze and pop it back on.......if the end that pops on the ball is broken, the whole cable has to be replaced....
Old 01-17-2012, 05:55 AM
Will have to replace the cable, the bushings gone. Was able to put the cable on, put a rubber band to hold it so I could at least move the car. More money spent when a cheap little part fails! Appreciate your help!
Old 01-17-2012, 02:44 PM
pas de quoi........
1998 Lumina - Can't shift into gear. Gear shifter button wont push in. UsernameX Lumina 7 01-03-2010 11:52 PM
1998 Lumina wont shift into gear UsernameX Lumina 3 02-18-2007 08:28 AM
48 Chevy Pickup Wont shift into gear weltertm General Discussion 17 05-14-2006 05:22 PM
97 Tracer Wont shift into gear qonthebeach General Discussion 0 06-18-2005 06:42 AM
Tranny wont shift into high gear ohst Pick-Up 1 01-24-2005 12:32 PM
