Old 01-14-2012, 09:46 PM
kais3 kais3 is offline
pinch bolt engineering
First off sorry for the non-technical names if they are confusing let me know. The metro is a 1996 1 liter 3 cylinder with 270000 miles. Alright I am asking for the knowledge of the World Wide Web on this one. It involves the pinch bolt behind the front tire that attaches the control arm to the tire. I replaced the driveshaft and control arms last april. Since I did that I had a slight steering annoyance going around corners. Well the other day I hit a big bump in town and the pinch bolt popped right off of the nub of the control arm creating mass mayhem, drive shaft came out and the tire looked like a wounded duck wing. After a quick fix in a snow storm I got the metro on a trailer and home. It is all a simple fix to put together except why that nub came out of the pinch bolt. The bolt I had in there was very worn you could see where the nub kept hitting it creating an area with no threads. So here is where I am scratching my head, is that nub held in there only by the threads of the bolt? I got a new bolt and tightened it as much as it would go and it does not pinch that nub securely. Is there a ridge that is supposed to catch that nub and mine is just worn off? I find it hard to believe that the threads of a bolt hold so much of the car together.
Old 01-15-2012, 08:40 AM
DeltaP DeltaP is offline
Re: pinch bolt engineering
Can you identify the "nub" more clearly? Are you talking about the ball joint? I dont think you're talking about a tie rod because the axle wouldnt pop out if one of them gave way.
Old 01-15-2012, 10:39 AM
Yes the ball joint on the suspension arm. It is indented like a pawn on a chess board. that indention allows the bolt to slide through with thicker areas above and below the threads in the bolt. it is just hard for me to believe that is the only thing that keeps that ball joint in.
Old 01-15-2012, 06:45 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
you probably didn't have the ball joint stud all the way up into the hole so the top of the ball joint was sitting on the through bolt instead of it going through the indented part of the stud. when ball joint stud is in the cosket far enough the rubber boot of it will be touching the part bolt goes through, its not uncommon to get have to tap the stud up the last 1/2" or so to get it up far enough
Old 01-15-2012, 08:25 PM
I cant say if i installed it right the first time or not. I can tell you where the bolt that comes in contact with the ball joint stud the threads where hammered flat. After installing it again i can move the suspension arm up and down just a bit allowing the ball joint stud to move a bit. the stud is flush with the top of the pinch bolt hardware with the bolt going threw the indentation. So i am guessing that if that bolt is the only thing holding that in, the small amount of play over time could hammer that bolt down and allow the stud to pop free?
Old 01-15-2012, 08:30 PM
Crvett69's Avatar
if its in tight and correctly it shouldn't move at all
Old 01-24-2012, 04:13 PM
Well the loose ball joint stud has turned into two problems. I found one of the bolts on the control arm rear bracket was rusted out and would not tighten. This allowed me to move the control arm up and down which was causing the ball joint stud to bang on the pinch bolt. The second problem and just as worrying is with everything connected I can move my tire in and out about a quarter to half an inch creating extremely loose steering. The drive shaft and ball joint move. The tie rods are secure and I have checked the steering knuckle bolts and strut mounts everything was tight. The hub nut was also torqued down to 129. I am not sure how to correct this problem. Any ideas would be very helpful. the drive shaft is brand new and the control arm with ball joint was new in may.
Old 01-25-2012, 02:06 PM
I was wondering if this half inch is suppose to be there? I have about a half inch of movement in the shaft side to side when everything is connected. unfortunately i do not remember if this was there on the original half axle. I cant get it to go in any farther but it doesn't come out with firm pulling either. Is it possible they gave me the wrong axle? my metro is a 1.0L. I cant figure out any other reason why my wheel would move that much side to side.
Old 01-25-2012, 04:39 PM
Sounds like the excessive play in the ball joint either caused the snap ring on the trans end of the splined axle to come off in the differential or was it on there to begin with? Dunno if the lack of that snap ring could cause extreme force enough to work on the ball joint/control arm or if the ball joint was just installed incorrectly.Or both.
Old 01-25-2012, 04:46 PM
Crvett69's Avatar
the snap ring might cause in and out play but if he can't pull it out its still on the axle. side to side play would indicate wrong axle or worn bearings inside the transaxle. it normal to have a little in out motion but not side to side and i would suspect your wheel bearings or a bad ball joint for hub movement
Old 01-25-2012, 06:08 PM
In my opinion if the axle was wrong it either wouldn't fit in or stay in. As many axles as I've done I always lay them side by side to compare critical dimensions. It only takes a minute. If the wheel hub bearings were that bad it would have either locked up by now or caused so much vibration and noise you teeth would chatter. The control arm bushings were probably so far gone that the thru bolt was bottoming out on the unthreaded portion of its shank resulting in extreme lateral movement. First you gotta address the control arm issue. You might have to replace it. Then inspect the steering knuckle for damage, replace the ball joint, remove the axle and inspect it for damage and if the snap ring is in place, get your fingers in there and inspect the splined side gear for damage, then check the side gears bearings for play or roughness. Then start back together with new parts. JMHO
Old 01-25-2012, 06:28 PM
Crvett69's Avatar
i have replaced front wheel bearings on metro where there were no balls left on one of the bearings and it was still running down the road, no shake but nice rumble noise. also on the control arm you can take off the front nut and the 2 rear bolts to remove it and see what shape everything is in. do not need to remove the 2 larger center bolts. if you take the axle back off you can then spin the hub and see if the bearings make any noise or if there is any play in them
Old 01-25-2012, 07:37 PM
I re-threaded the rusted out bolt hole for the control arm and the new bolt can be tightened. the control arm with the ball joint was replaced in may and still looks to be in good condition. I attempted to pull the drivers side axle out of the trans axle but am unable to do so even with the assistance of a crowbar and plenty of frustration. i then took apart the passenger side to see what i could see. that side came out no problem like they have done in the past. looking through the other side i can see the axle there is the gear rod in between and the drivers side axle is touching this rod. now i think and may be wrong that the axle on the drivers side is too long. after popping the passenger side out the half inch gap that is currently on the divers side was apparent with more force i could snap the c clip all the way in and the cylinder would be touching the seal. I can not do that on the drivers side since it is already touching the gear rod. However i cant get the driver side out now so that C clip must be snapped into something. I still want to get that bugger off and take it in to a store and compare, just to see. Tomorrow i am going to replace the tire bearings seeing as the car has 270000 and i know i haven't done it in the last 110000. Thanks for all your help guys.
Old 01-25-2012, 09:42 PM
Crvett69's Avatar
try turning the axle 1/2 turn and try popping it again, something you have to have the c clip facing just the right direction to pop it loose. if you keep doing that eventualy it will come out
Old 01-27-2012, 12:57 PM
alright so the wheel bearings where still in good shape. I still cant get the axle out so i went through and re read everything you guys wrote and made notes to check everything. My assumption that the control arm and ball joint where not the issue because they were new blinded me. the ball joint has excessive play in it and the boot around it feels like there is no grease in it. hope there was a warranty on this. I will let you guys know if this fixes my problem. Thanks again for all the help.
Are 4g63 6 bolt engine parts interchangeable with the 7 bolt 4g63? saber85 Eclipse Problem Diagnosis 0 02-25-2011 09:16 PM
How tight? steering shaft pinch bolt sikz3 Problem Diagnosis 1 07-09-2007 09:43 AM
93 talon ES, 6 bolt engine or 7 bolt? macder Off-Topic 0 09-17-2004 08:54 PM
6 Bolt Engine Conversion Questions Afrokid Off-Topic 8 01-20-2004 08:54 PM
2g Parts in a 6 bolt Engine Afrokid Off-Topic 5 01-19-2004 01:35 PM
