Old 01-17-2004, 10:18 AM
Afrokid's Avatar
Afrokid Afrokid is offline
Send a message via AIM to Afrokid
2g Parts in a 6 bolt Engine
My biggest problem about the 6 bolt engine is the 2g parts. when i order parts should i order them for the 90-94 models or the 95-99 models? Like when i want to get new pully's should i order the older versions or the newones for the 2gs? http://www.machv.com/macvalpulkit.html
So my question is should i order 1g parts or 2g parts for my 6 bolt engine?
"Cant you see that your smothering me, holding too tightly, afraid to loose control cause everything that you thought i would be, is falling apart..right in front of you....every step that i take is another mistake to you, and every second i waste is more then i can take"
Old 01-17-2004, 02:43 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
its a 1st gen motor so use the 1st gen parts... alteast for the pullies and the other exterior parts, for the internal parts the 2nd gen pistons and rods will work but the crank will not! anything that bolts on to the engine usually has to be from the same generation, give or take a few parts! good luck
Old 01-17-2004, 02:56 PM
EclipseRST's Avatar
Banned
oh yea and the 6 bolt was only in the 90-92... 93-99 was the 7 bolt!
Old 01-17-2004, 04:57 PM
Afrokid's Avatar
Re: 2g Parts in a 6 bolt Engine
and how would i specify i want a 6 bolt engine on one of the sites where i can order engines from?
Old 01-18-2004, 06:45 AM
EclipseRST's Avatar
Banned
just tell them you want a six bolt motor... and if they still dont know tell them you want a motor from 90-92 out of either a turbo eclipse, talon, or laser! just look at it and see if it is a six bolt or not!
you do know how to tell if it is a six bolt right?
--- six bolts that hold the fly wheel on (just incase you didnt)
Old 01-19-2004, 01:35 PM
kjewer1 kjewer1 is offline
AF - Advisor
Some 92s are 7 bolts
For anything internal use 6 bolt parts, except for pistons if you want the higher 2g compression. For externals stuff it depends on what swap you doing. Just the block? Everything inside the timing belt cover will be 6 bolt (use 91), everything else will be for your year car. If you do the whole motor swap with head then many more parts are going to be 1g parts. See the swap guide at www.magnusmotorsports.com for a list of what is used from your car and what is required from a 1g/6 bolt. that will give you a general idea.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
