Old 01-13-2012, 03:34 PM
MrCreosote MrCreosote is offline
Transmission Acting Up and Terrible City MPG
I had the trans replaced in my 2000 and the first thing I noticed that the transmission was very aggressive upshifting and locking-up so that engine rpm was kept low and loaded.
Now the transmission has lost this characteristic and runs to higher rpm before upshifting and lockup is also not as aggressive.
Going hand in hand with this is a change in city mpg from 14-15 to about 12.
I suspect the transmission pump is starting to wear out and there is a loss in transmission fluid pressure. On the highway, rpm is high enough that proper fluid pressure is present and I get the 25 mpg that is typical.
So that leaves me with what to do about the trans.
Fluid change and perhaps a higher viscosity synthetic ATF may be advantageous.
Any thoughts?
Thanks
Tom
Old 01-14-2012, 06:46 PM
wiswind wiswind is offline
Re: Transmission Acting Up and Terrible City MPG
Fluid change would be my first thing.
The fluid should be changed at least every 30K miles in normal service.
Remember that cold weather short trip driving will KILL your fuel economy.
The transmission will also shift differently when the fluid is cold......a high quality synthetic that is listed for the Mercon V specification will help with this.
The Windstar tranny has a transmission fluid temperature sensor that the PCM uses to control shift points for colder weather.
My new-to-me Sienna annoys me until it warms up because the computer in that vehicle holds the shift points at a higher RPM than I like until the transmission fluid warms up.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 01-14-2012, 09:16 PM
FishFind FishFind is offline
One Hot Shot
Any dtc?? sound like fluid or overdrive issue. Like your tcc is always on.
Old 01-15-2012, 11:15 AM
No codes although I have an ABS light that occasionally comes on (code is no signal @ LR sensor). The fluid is way overdue for a change. Just bot my Mytivac 7201 (!) [Xmas present to self] and want to put syn ATF in. Amsoil seems like my preference, but the Mobil 1 might be cheaper - I have to check that out.
2002 Grand Prix MPG improvement and Check Engine Light gone!!! fixed by chance mtsav8or Grand Prix 1 07-11-2011 09:54 AM
Terrible gas MPG around town cardgunner Windstar 3 04-29-2011 02:25 PM
Taurus transmission light and problems mikecorki Taurus | Taurus Wagon 4 06-01-2009 06:39 AM
thunderbird city MPG? tbird-pax Thunderbird 3 01-31-2007 10:50 AM
Transmission acting up skarloey Grand Prix 25 11-13-2004 09:09 PM
