Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 01-11-2012, 01:02 PM
96DEVILLE 96DEVILLE is offline
01 deville pressure hose
I replaced the power steering pressure hose. Streeing fine but when i turn the wheels i get a faint sound like the fluid is low..its not, what cuuld it be?? 01 deville..thank you carl P.S. DID NOT HAVE NOSE BEFORE....
Old 01-11-2012, 02:23 PM
maxwedge maxwedge is offline
A990 racer
Re: 01 deville pressure hose
Did you let the air bleed out, proper way is wheels off the ground, turn lock to lock a couple of times, then leave the filler cap off for a 1/2 hour, let the car down and fill as necessary, I assume you used the right fluid.
Old 01-11-2012, 05:49 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Hello,
Just in case (and to let other people know what kind of noise), is it making noise like this?
http://www.youtube.com/watch?v=Q35EbhjIeHE
I did the same thing to my car (replaced the pressure line) and ended up with the same result like you. I'm still figuring out what to do...
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 01-12-2012, 04:49 AM
Originally Posted by olopezm View Post
Hello,
Oscar.
mine sound like when fluid is low and it is quite till i turn the wheel
Old 01-12-2012, 04:57 AM
Originally Posted by maxwedge View Post
did you let the air bleed out, proper way is wheels off the ground, turn lock to lock a couple of times, then leave the filler cap off for a 1/2 hour, let the car down and fill as necessary, i assume you used the right fluid.
thanks, i will try that .i did turn wheel from lock to lock but it was on the ground... When i removed cap i would hear air excape but i did it like 10 times and still have the nose....fluid i bought in auto zone it just said power steering fluid..ill check if it is the right one...thanks carl
Power Steering hose/Pressure Hose burijon Intrigue 6 11-30-2018 11:18 AM
power steering pressure hose leak Illinoisboy Cavalier Problem Diagnosis 11 12-16-2009 09:20 PM
Power Steering Pressure Hose Tech_n Grand Prix 3 01-19-2005 10:30 AM
How to change Power Steering Pressure Hose? tahoe964wd Tahoe 0 11-20-2004 06:39 PM
Replacing the power steering pressure hose BassGuy21 Cutlass Series 2 09-12-2004 12:45 PM
