Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-11-2012, 06:04 AM
mishalah's Avatar
mishalah mishalah is offline
ign switch replacement
Have any of you replaced your ignition switch (not the shop, you yourself)?
Did you (can you) change just the wiring component without changing the key/tumbler?
What happens to the key remote and other security related components?
Old 01-11-2012, 06:51 AM
tempfixit tempfixit is offline
Re: ign switch replacement
What year is the vehicle??
Old 01-11-2012, 12:59 PM
mishalah's Avatar
2005 Suburban 1500 LT awd/tow pkg/etc.
Old 01-11-2012, 01:05 PM
j cAT j cAT is offline
you talking about the lock cylinder or the ignition switch ?
ignition switch will not affect key or security.
If the lock cylinder is giving you problems go to a auto lock smith..
the switch is on the steering collum down low
Old 01-11-2012, 01:11 PM
mishalah's Avatar
I'm thinking about replacing the switch...not wanting to replace the key or tumbler. After replacing the TCC solenoids and inner harness to get rid of a P2761 code...and having it come back even tho the tranny shifts fine...I will try the ignition switch solution that has worked for others.
2004 Yukon XL Denali Luxo-barge for towing. 6.0L AWD grandpa hauler
2005 Suburban 1500LT/awd/tow/everything else...soccermom cruiser
2008 Nissan Versa HB...wife's skateboard
1997 Jaguar XK8 convertible...best road car ever
1966 Mustang GT convertible...fully restored concourse show car
Old 01-11-2012, 05:59 PM
the switch is not specific to your vehicle..just a switch. locate and replace the old switch with new ..you have a rod that connects to it from the locking key cylinder.
Old 01-11-2012, 06:47 PM
mishalah's Avatar
Thumbs up Re: ign switch replacement
Good. It does look like a "plug and play" type of part, doesn't it.
Thanks.
Old 02-02-2012, 04:32 PM
mishalah's Avatar
Need to revive this for the moment. My son was looking for the location of the switch ('05) but didn't see it on the column. It was late and getting dark, but he thought it might be up at the top. If it's down on the column, where exactly should I find it?
Old 02-09-2012, 11:33 PM
mishalah's Avatar
First, the switch, according to reference pdf's I have is directly under the key lock, and on the top of the column under the cover in front of the steering wheel. That said, it appears the plastic cover is held together with some kind of odd fastener...not anything that can be unscrewed with any normal tool from the access holes underneath.
SO...how the heck do I get the cover halves apart so I can access the switch? I disconnected the battery, but are there some security components that might disable my truck if the process isn't done right?
Old 02-10-2012, 08:45 AM
yes this vehicle has the ignition sw under
/ next to the lock cylinder. it is a tough one to get at . the screw I believe your refering to is an inverted 4 mm torx.
its a tricky job especially if the sw gears are not set correctly. disable air bag before working it as well as the battery ground .
Old 02-10-2012, 03:17 PM
mishalah's Avatar
Now the drawings I see show the steering wheel removed, and along the way there is some command to do so. I cannot see why that is necessary just to R&R this switch. However, I also see that there is info to R&R the ignition keyset, which requires aligning the gear on the ignition switch, the keyset, etc. I can understand that, but if I only want to R&R the elect. switch from the connections, and the keyset and column are not moved, why would it (or would it) be necessary to mess with the keyset at all? Shouldn't that ignition switch just pull down and out, then reverse to reinstall?
Old 02-10-2012, 05:39 PM
I do not believe that the lock cylinder or the steering wheel need be removed. just the covers so that you can get access to the switch. it should slide out. I saw some pictures on line showing some of this.
Old 02-28-2012, 05:00 PM
mishalah's Avatar
OK..replaced the switch yesterday. Easy removal of the tilt lever and then the lower column shield. The switch replacement was easy, but the sheild was a beotch to get back into exact position. But.....new switch did not seem to solve the problem as the 2761 code came back quickly. Gotta be a power interruption somewhere in that full circuit.
Old 03-01-2012, 07:45 AM
Levithan9 Levithan9 is offline
Check out these postings....
PCM Harness
- THIS PROBLEM WILL PROBABLY BE A COMMON OCCURRANCE. VEHICLE CAME IN WITH CHECK ENGINE LIGHT P2761. REPLACE TCC PRESSURE SOLENOID .THE SOLENOID DID NOT FIX THE PROBLEM.WIRING HARNESS FROM THE PCM NEAR THE LEFT FRONT WHEELHOUSE WAS LAYING ON TOP OF THE CONTROL ARM AND FRAME AND CUT THE HARNESS.
And this...
Found low voltage on IGN0 fuse in drivers side dash fuse panel. Voltage drop was 1.5V from pos post on battery. This fuse protects trans module so multiple trans codes set. Replaced Ignition switch.
Check the fuse of the drivers side fuse.
And this....
Transmission Range Switch
- water intrusion to trans range selector,causing fuse to blow.replaced trans range selector switch and connector pig-tails.
Hope this helps.
2nd time a charm, replace ign switch Legacy Man TrailBlazer | Trailblazer EXT 9 04-18-2008 03:12 PM
95 Lumina LS 3.1 won't start after ign. switch replacement campkids Lumina 5 01-13-2006 08:53 AM
Ign. switch? wire shorted? or other? scb Achieva 3 01-19-2005 10:02 PM
Cheapest place to buy a 2002 Focus ign.switch jamie390 Focus | C Max 0 09-22-2004 09:27 AM
Need help in removing ign switch 98 silverado nd1 C/K 0 07-23-2004 06:25 AM
