Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 01-09-2012, 02:36 AM
akmcul akmcul is offline
Lights flashing while driving
1995 lincoln lights blink not completely off just flashes.
Old 01-10-2012, 06:03 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Lights flashing while driving
Would you describe it more like dimming while driving?
If so there is a big chance a connector is dirty. It is located between the battery and the Fuse junction box under the hood; it's gray colored and has two wires on it can't remember the exact colors but I remember seeing green and yellow.
A quick test would be to turn you headlights on while idling and wiggling that connector if the lights change then you can either clean the terminals in both sides of it or cut it and solder the wires together. BE SURE TO DISCONNECT the battery, you don't want to cause a short in the wiring.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 01-10-2012, 08:23 PM
Flashing like dimming.
Old 01-11-2012, 06:04 AM
snshddog snshddog is offline
If it is a quick "dimming" with the engine running but a steady beam with the engine not running then I would say the rectifier in the alternator is bad.
Old 01-11-2012, 05:05 PM
olopezm's Avatar
Check the connector I mentioned. It is a very common problem with these cars. I, personally, decided to removed it and solder all wires together.
Oscar.
'02, 58K miles, battery light flashing while towing trailer in hilly terrain Fordina M Bodies 1 03-18-2011 08:46 PM
SES light flashing while driving CrazyHorst Grand Prix 1 12-18-2008 07:39 PM
Temp Light Flashes While Driving LEW--C Trans Sport 2 09-12-2006 05:17 PM
94 Bonneville clicks, lights flash while attempting start spoooner Bonneville 2 08-22-2005 09:05 PM
Dashboard lights up while driving jlomaz Odyssey 3 01-18-2005 04:44 PM
