Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-08-2012, 04:11 PM
xv920r xv920r is offline
strange knock 91 Dakota 2.5l
Complete engine rebuild about 2 yrs. ago including replacing cracked head. Suddenly a sound exactly like a rod knock appeared. Replaced bearings but neither crank or bearings showed any signs of wear. Problem was not solved. Under no load (hood up) the engine has a loud buzzing rattle at about 2500 rpm. I can't locate the sound source. Arghhh. Ideas? Thanks
Old 01-08-2012, 05:35 PM
jamesslcx jamesslcx is offline
Re: strange knock 91 Dakota 2.5l
xv920r, hard to diagnose without hearing. I always get a plastic handled prybar and while engine is running safely place it at various locations and put my ear to the handle and listen. This acts as a poor mans stethoscope. How is the oil pressure and is this the Chrysler or Jeep 2.5 in your truck?
Old 01-11-2012, 08:39 AM
The oil pressure is right on spec. On the road I hear the noise as the engine is "floating" at minimum load...just as bad bearings would. It is more apparent when the engine is warm. I tried heavier oil before I changed the rod bearings...no effect.
Old 01-11-2012, 08:41 AM
Engine is Chrysler ohc 2.5l.
Old 01-11-2012, 01:58 PM
xv920r, maybe the balance shaft in the engine, sometimes they can be noisy. A lot of the 2.5's were noisy, I've had a few in cars but the noise never hurt anything.
Old 01-11-2012, 03:06 PM
Scrapper Scrapper is offline
AF Premium User
you think it might be a rist pin to piston?
Old 01-11-2012, 04:27 PM
I would probably just drive it, I know the noise is annoying. Maybe you could get a oil analysis just to determine wear metals.
Old 01-13-2012, 11:00 AM
AF Premium User
have you tried taking belt off for a min. and start it and see if noise leaves if it does it may be your harmotic ballancer? just a thot...
good luck.........
Problems with my 1999 Mazda Millenia V6 2.5L IcyBob Millenia/Xedos 9 0 01-04-2010 06:04 PM
Dakota 2.5L with bad cylinder? trifit1 Dakota 0 02-24-2008 07:38 PM
99 Dakota 2.5L light tapping noise from eng 2cheap4new Dakota 0 06-05-2007 04:27 PM
93 dakota 2.5L problems gombos Dakota 3 01-19-2005 07:47 PM
94 dakota 2.5l truck doesnt start digolbick Dakota 1 12-19-2004 07:07 PM
