Old 01-07-2012, 05:35 PM
Ryan546 Ryan546 is offline
Alero Mileage
Hey all,
I bought a 2002 v6 3.4l, 2 door Alero about 2 weeks ago. The car has 113,800 miles on it.
I think I should be getting better fuel economy than I am currently. I filled it up and reset the trip. I'm at 200kms and down to 1/4 tank. Is everyone getting roughly the same mileage?
The service engine light and ABS light come on periodically as well. I have read through the forums and am going to check the wheel hub and sensors. Could a bad 02 sensor be causing this as well?
Thanks
Old 01-07-2012, 05:37 PM
Re: Alero Mileage
To add to my previous post.
I know the rear brake pads need to be replaced. Would that contribute to the ABS light?
Old 01-07-2012, 06:33 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Alero Mileage
Rear pads being worn would not cause ABS light to come on. Have you figured what your actual mileage is?
The Following User Says Thank You to gmtech1 For This Useful Post:
Ryan546 (01-08-2012)
Old 01-07-2012, 06:43 PM
skeeter123 skeeter123 is offline
Re: Alero Mileage
I usually get ~25 mpg in town, and 29-30 on highway. (2000 Alero 3.4L, 4-dr). You could try getting your codes read for free at an autoparts store. They typically can't read ABS codes, but would tell you the code associated with the service-engine-soon light.
The Following User Says Thank You to skeeter123 For This Useful Post:
Old 01-07-2012, 07:26 PM
Re: Alero Mileage
My actual mileage is 16 mpg, I drive mainly just to work and back in the city. No led foot, I drive respectfully. Only using the power when I need it ie. passing. I'm going to check the codes tomorrow as my friend has a diagnostic scanner. I'll post back tomorrow, thanks for the help!
Old 01-08-2012, 02:25 PM
Re: Alero Mileage
Scanner came up with nothing. I'm assuming it's the wheel bearing on the passenger side. Is the bearing inside the wheel hub assembly or can it be swapped with out a new hub?
I re-did my math for the mileage and I'm getting 18.9 mpg. Right around where it should be. I'll probably replace to 02 sensors anyways since they have never been changed after 113 000 kms.
Thanks
Old 01-08-2012, 02:31 PM
gmtech1's Avatar
Re: Alero Mileage
The hub and bearing come as an assembly. Remove caliper bracket and rotor, axle nut, three bolts retaining the hub assy, disconnect the ABS sensor.
2000 Alero 2.4-skips, jerks, dies, poor gas mileage summersdad Alero 8 03-08-2012 09:23 PM
2003 alero can't start pdxalero Alero 8 09-06-2009 02:00 PM
2003 Alero quits with air conditioning Stefphelps Alero 3 04-29-2009 07:16 AM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 10:04 PM
99 alero mileage demanufactured Alero 5 03-03-2004 05:34 PM
