Old 01-07-2012, 06:45 AM
excelglen excelglen is offline
03 taurus v6 lean bank 2
idles poorly, missing at hi rpm. tested bank2 lean. ??? what does that mean? bad or dirty injector?
Old 01-07-2012, 07:56 AM
tempfixit tempfixit is offline
Re: 03 taurus v6 lean bank 2
Welcome to AF,
What was the code number.
I would look for a vacuum leak, spray carb cleaner on the vauum lines and intake, if idle increases you have found your leak.
lean code means there is unmetered air entering the system after the Mass AIr Flow sensor before the throttle body.
Bank 2 on a Ford is the clyinders cloest to the radiator or driver side of engine.
The Following User Says Thank You to tempfixit For This Useful Post:
excelglen (01-16-2012)
Old 01-07-2012, 10:46 AM
Thanks I ' ll get that a try
Old 01-07-2012, 11:06 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The leak would not necessarily need to be before the throttle body, it could also be an intake manifold, manifold vacuum port, PCV system, etc.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
Old 01-07-2012, 12:30 PM
-Rod
I stated that wrongly shorod, I was trying to say that the MAF sensor was just before the throttle body and need to look at vacuum lines and intake gaskets like you say.
thanks for clarifying that.
Old 01-16-2012, 02:30 PM
The rubber tube going from the PCV to the intake manifold FORD 2F1Z6C324A PCV VALVE AND VENT HOSE. About $25 at Ford no tools required to replace it . Thanks on all
1997 Lean bank 1, lean bank 2 Baja SS Jimmy 5 03-08-2006 11:00 AM
Check engine light- lean bank trainutz Prism 1 06-22-2005 11:28 AM
system running to lean bank 1 code P0171 e_t_phonehome Windstar 2 03-02-2005 10:41 PM
system too lean bank 1 and 2 Dcarlson5 Blazer 10 02-25-2005 11:57 PM
P0171 ecu code - mix too lean bank 1 mscmor Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 07-19-2003 08:14 PM
Tags
ford , lean , taurus
