Old 01-25-2005, 12:40 AM
Dcarlson5 Dcarlson5 is offline
system too lean bank 1 and 2
what could cause this?
My engine is running rough and the error code say system too lean bank 1 and system too lean bank 2
Also sometime it says misfire cylider 4 or random cylinder misfire but what is the cause of too lean?
Old 01-25-2005, 12:55 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
What codes are you getting? What year is it?
Old 01-25-2005, 01:09 AM
Re: system too lean bank 1 and 2
It is a 98 blazer 4 wd vin w
Old 01-25-2005, 01:16 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Any other symptoms like pinging under load at all?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-25-2005, 01:36 AM
Re: Re: system too lean bank 1 and 2
No just knocks A little at first when it is started.
But when it gets to running it runs fine but idles alittle bit rough.
Old 01-25-2005, 06:35 PM
ricksza's Avatar
ricksza ricksza is offline
Lean means too much air or not enough fuel. Check for a vacuum leak, clogged fuel filter or low fuel pressure.
Old 01-25-2005, 07:15 PM
BlazerLT's Avatar
AF -Advisor
Knocking at startup means you are probably using a Fram oil filter.
Also, are you using 5w30 like the manual states?
Old 01-26-2005, 01:03 AM
blazes9395's Avatar
Newbie mod
A low fuel pressure can cause the little poppets at the end of the injector nozzles to not work properly and stick or not even open, causing a random cylinder misfire and a lean mixture.
Old 02-24-2005, 06:40 PM
iamryn iamryn is offline
My 5.7 Vortec in my 96 Sierra 3500 has the original problems of this guy with the pinging under load. But I'm only am lean on bank 2.
I replaced the intake gasket, and originally stuck the distributor in wrong got the 1394 code (I think, the cam/crank sensor corrolation problem), I got taht code gone, and it seemed to run fine (when in park), a slight ping when I backed off at 4000Rpms, but once I got on the road it seemed just as bad as before I got rid of the 1394 code. I can smell the fuel and watch the gas gauge go down, Im probably getting about half the usual MPG. I am going to check the Fuel pressure, the pressure regulator, and the MAF tommorow, but I figured I'd post up since you seem to know what might be causiing this and I can have something else ot check out. Thanks.
Old 02-25-2005, 05:16 AM
ricksza's Avatar
Re: Re: Re: system too lean bank 1 and 2
If your reading lean just on Bank 1, could just be a bad sensor. Fools the computer into thinking that it's lean and trying to richen up the mixture. Make sure that you verify the O2 Sensor operation. Will it read on the rich end? To check, with the engine running have the scanner hooked up and spray some carb cleaner down the intake. Both front O2 Sensors should bounce up near 1.00 volts as long as you're spraying.
Old 02-25-2005, 11:57 PM
BlazerLT's Avatar
AF -Advisor
Please post in the appropriate forum section.
