Old 01-05-2012, 09:57 AM
Spit Spit is offline
Should I use Gasket Shellac?
I am planning on replacing both the valve cover gaskets and the lower intake gasket(thin aluminum gasket in the valley) Should I use Indian Head gasket shellac on either of these applications? I know I am to use a small spot of Hi-Temp RTV on the corners of the intake gasket where it fits up to the head.
Everything I read talks about the gasket surfaces being completely clean & dry...but when I read the label of the shellac it sounds like they recommend it....any thoughts and experiences out there? I did use it on the water pump and it worked fine.
Spit
Old 01-05-2012, 08:33 PM
jamesslcx jamesslcx is offline
Re: Should I use Gasket Shellac?
Spit, I've used it a lot in the past, but not so much lately. I would guess it wouldn't hurt to use it.
The Following User Says Thank You to jamesslcx For This Useful Post:
Spit (01-06-2012)
What kinds of gas I should use for S40 1.9t? ouyangcui S40 3 04-11-2008 04:29 PM
what is the oil i should use dandersen Ram Pickup | Ram SRT10 8 02-20-2008 11:27 PM
Should I use gasket sealant? Anavel Escort 4 08-23-2007 11:55 AM
Things and products we should use. zachzchw Blazer 7 03-27-2006 01:46 AM
Which wing do u think i should use??? JDM Wagon Car Modeling 14 07-14-2003 05:16 PM
