Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-04-2012, 04:27 PM
78silverbird 78silverbird is offline
2000 Montana won't start at a loss
I have a 2000 Montana 3.4L that will not start, I am 90% sure it's something to do with the fuel system but can't figure out what the problem is. I turn the key and hear the pump but there seems to be no gas getting to the motor, if I spray some gas directly into it it will turn over but then dies. First I thought it was bad gas then fuel filter but both have been addressed and still nothing. The pump seems to be working since it was pumping gas on the ground through a leak I found with the new filter connection. Please any help would be appreciated.
Old 01-04-2012, 05:31 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2000 Montana won't start at a loss
Need to check fuel pressure, should be 52-59psi. If you don't have a fuel pressure gauge, some parts stores have them to rent.
Old 01-05-2012, 01:03 PM
How do I go about checking the pressure? Where is the test port located on this van? Will I be able to get a reading if the van won't start?
Old 01-05-2012, 01:08 PM
gmtech1's Avatar
The port is on the passenger side, on the fuel rail, by the p/s pump. Hook up fuel pressure gauge, turn key on, pressure should jump to specification and stay there.
Old 01-06-2012, 02:44 PM
Ok so we rented a gauge and the pressure tested from 58 when the pump was running to a steady 52 when it was done. Now what?
2000 Pontiac Montana Transmission Problem brandon1766 Montana/Montana SV6 3 07-23-2011 09:36 AM
2000 Ford Escort won't start caine Escort 4 06-10-2011 08:40 AM
1999 Montana won't start bat27 Montana/Montana SV6 1 07-06-2009 01:10 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
Pontiac Montana won't start-hissing sound from ignition key DHolland Montana/Montana SV6 2 08-22-2007 08:06 PM
