Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-04-2012, 11:04 AM
rtoney rtoney is offline
1997 Suburban won't start
My 97 Suburban died and will not start. Things I have done:
1 Changed fuel filter
2 Changed fuel pump twice
3 Checked fuel pressure 60psi
4 Changed plugs and wires
5 Changed rotor and cap
6 jumped switch to make sure pump runs
The Suburban will start only if I pour gas in the throttle body and will idle as long as I continue to pour gas in but will die when I quit.
Old 01-15-2012, 06:18 PM
jamesslcx jamesslcx is offline
Re: 1997 Suburban won't start
rtoney,Have you checked injector and wiring?
Old 01-17-2012, 09:23 AM
Thanks for your response. Next warm day I will try and start it and then pull a plug to see if it is wet. I don't think it will be since I can start it by pouring gas in the throttle body. Not sure if there is a fuse for the injectors or not and not sure what wiring I would need to check.
Thanks again
Old 01-17-2012, 10:34 AM
777stickman 777stickman is offline
The fuse for the injectors is the ECM 1 in the underhood fuse block. This fuse also powers the ign module so it's probably ok.
The VCM controls the ground signal for the injectors.
Fuel pressure needs to be 60-66 psi.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-24-2012, 09:39 AM
Tried to start the suburban and then checked a plug, there was gas on the plug but it still will not start.
Old 01-24-2012, 04:01 PM
rtoney, interesting, seems like with the spark plug wet it's getting fuel. Did you check for spark?
Old 01-24-2012, 07:25 PM
He said in his original post that it would run as long as he poured gas in the T/B?? So it seems the spark is good. I'm at a loss at this point.
57 Chevy 210
Old 01-24-2012, 08:44 PM
777stickman, you are not the only one, only idea I have is bad fuel in tank?
1997 Saturn SL not starting DebbiR SC/SL/SW 19 07-17-2016 08:25 PM
97 Suburban won't start, runs with starting fluid rtalnadge Suburban 6 08-30-2014 04:15 AM
88 Suburban Won't Start jgauthier13 Suburban 2 02-25-2011 08:18 AM
2002 Chevy Suburban cranks, won't start adamj_rogers Suburban 1 06-17-2010 07:34 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
