Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-24-2011, 12:47 PM
jgauthier13 jgauthier13 is offline
88 Suburban Won't Start
A while ago, I had the wires by the starter fixed because of a similar problem and now it is doing it again. This time, it started with the battery not staying charged. Battery and alternator both tested perfect. Sometimes there was enough to start and sometimes not. While jumping the truck one day, cables fell and touched. Occasionally, the electricals will work, but as soon as I go to crank it over, the whole system shuts off. Any ideas?
Old 02-25-2011, 06:59 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 88 Suburban Won't Start
Check the big wire from alternator to battery.
Also alternator should be tested on vechicle.
And make sure battery cables and cabel ends are good and clean.
MT
Old 02-25-2011, 08:18 AM
MT-2500's Avatar
AF - Advisor
Also need to know if gauge or red light for alternator?
If red light does it come on key on?
And go off or stay on engine running?
If gauge are you getting voltage to alternator sall wire key on or engine running to engauge alternator charge?
MT
2002 Suburban - Motor Swap - Won't Start mrharris32 Suburban 5 09-22-2010 06:48 PM
2002 Chevy Suburban cranks, won't start adamj_rogers Suburban 1 06-17-2010 07:34 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
93 suburban won't start northflyer C/K 4 02-18-2005 02:18 PM
96 Suburban won't start, unless... plnestel C/K 3 03-22-2004 06:36 AM
Tags
ignition , start , suburban
