Old 01-04-2012, 10:45 AM
Robdaparamedic Robdaparamedic is offline
'01 and '02 Allignment didn't solve the wobble ???
I recently had all 4 tires replaced with studded snows and they were spin balanced. Before I did this I had a bad wobble/shake in the rear tire. (driver side) I figured it was a bad tire and the new tires would fix this. NOT
Anyone of sound mind and body would conclude it is now an allignment problem. I just got back from a dealer where my best buddy works and had the allignment done. It did NOT show anything wrong with a rear tire but one of the front tires were slightly off. I left there and wouldn't you know it, the shake/wobble is still there. It only happens between 40 and 48 mph. It is pretty bad when it does occur. It doesn't happen when I'm accelerating through 45 quickly, just when your doing normal driving. Since most speed limits are 40 to 55, it is pretty annoying. Anyone have any suggestions as to what else could be causing this shake/wobble. It doesn't do it over 50 or under 40. Thanks in advance.
Rob
Old 01-04-2012, 11:49 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: '01 and '02 Allignment didn't solve the wobble ???
Alignment will not cause a wobble feel, if you are sure all the tires are running true, check the wheel runout, you may have a bent wheel. Shocks are ok?
Old 01-04-2012, 01:49 PM
Shocks aren't new but not a problem. The tires were just put on and spin balanaced. I'm having them re-checked Saturday. If a rim was bent, wouldn't that cause the balance to be off?? Thanks
Old 01-04-2012, 02:47 PM
gmtech1's Avatar
Yes and no. I have seen bent wheels balanced before. Do you feel the wobble at all at slow speeds? Does it change if the wheels are rotated ft to back?
Old 01-05-2012, 12:28 PM
happydog500 happydog500 is offline
To have A balance and not get it right is not that uncommon. I'd not worry until after the rebalance.
I had a bent wheel and after I got a new one, I couldn't remember which one it was. They all balance out fine, so yes, you can balance a bent wheel.
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 01-05-2012, 03:56 PM
Tech II Tech II is offline
A bent wheel may balance, but it can cause a wobble that can be felt....
Old 01-05-2012, 04:16 PM
Thanks for clarifying. I forgot to mention that. I could of given the wrong impression. What I was thinking was you can "balance" a bent wheel in the shop, but it can still have problems with the feel even tho it's been "balanced."
Thanks for clarifying,
Chris.
New Balance 662
Trek 8000
Old 01-05-2012, 04:31 PM
gmtech1's Avatar
Even though it's balanced, it's still bent.
[URGENT] - '01 Civic lost and Axel Seal and now... Doubletap '01-'05 Civic 0 11-05-2007 09:14 AM
Buying...... '01 or '02? wowchad Excursion 9 10-04-2005 08:03 AM
2001 GA - Replacing Cat. & O2 Didn't Solve Problem ppangel Grand AM 0 09-12-2005 05:12 AM
2002 Caster and Camber Allignment Le Gimp Ram Pickup | Ram SRT10 1 10-06-2004 03:29 PM
'01 to '02 Yukon Denali mandirigma01 Yukon 9 05-20-2004 12:46 PM
