Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-02-2012, 08:22 PM
heymanz heymanz is offline
car doesnt start
i have a 95 88 with a 3800 engine i was driving n the engine stalled it cranks but wont start i think the timing chain many have jumped is there a easy way to check this without tearing it apart and if the chain did jump would the valves gotten bent thanks for any help you may offer
Old 01-03-2012, 03:43 PM
maxwedge maxwedge is offline
A990 racer
Re: car doesnt start
If the chain went bad you it would almost be certain the valves are bent, you could do a compression test. But does it have spark and fuel pressure?
Old 01-03-2012, 04:08 PM
Tech II Tech II is offline
Why are you ASSUMING the chain jumped? Is it because it makes a different sound while cranking?
I can remember the old "C" motors having this problem because they used a composite cam gear that would strip and jump the timing.....more often than not it would bend the push rods rather than the valves.....
The "L" motor had a steel cam and this didn't happen.....I can't even remember hearing about a chain that jumped due to sprocket, tensioner or chain failure.....not that it couldn't happen......but if the engine had regular oil changes, it shouldn't happen......
I'd check compression before condemning a chain....if compression is ok, and if there is no spark or injector pulse, I'd be leaning towards a crank sensor or ICM.....if there is spark and pulse, check fuel pressure.....
If pressure is ok, disconnect the MAF and see if it will start.....
Have you checked for codes?
my car will run for a few days then the HOT light comes on and the car doesnt start HEET Ninety Eight 0 08-30-2010 11:50 AM
car doesnt start right stever27 General Discussion 1 08-22-2005 02:12 PM
93 Taurus-Replaced Water Pump-Car doesnt start MrTaurus Taurus | Taurus Wagon 3 02-16-2005 06:26 PM
Help!!! My car doesnt start coz theres no spark!! Heist '88 - '91 Civic | CRX | Wagon | Shuttlee 7 08-12-2003 08:46 PM
