Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 01-02-2012, 04:22 PM
Timster1 Timster1 is offline
Cool i need guidance
i have a 1999 chrysler sebring convertible jxi. anyone have any experience with why the cluster lights in the dash would suddenly stop working while the fuses are good?
Old 01-13-2012, 03:20 PM
jamesslcx jamesslcx is offline
Re: i need guidance
Timster1, have you fixed your problem yet?
Old 01-17-2012, 02:28 PM
Re: i need guidance
no i havent. can u help me?
Old 01-17-2012, 02:32 PM
Re: i need guidance
you can call me at 860-517-9040 if its easier. Thanks
Old 01-17-2012, 04:58 PM
Re: i need guidance
Timster1 does your car have an adjuster that dims and brightens the dash lights ? Does everything else work ok as far as interior lights?
Old 01-17-2012, 10:58 PM
Re: i need guidance
yes
Old 01-17-2012, 11:02 PM
Re: i need guidance
actually the dimmer switch brightens all the other dash lights but doesn't turn the interior light on.
Old 01-17-2012, 11:06 PM
Re: i need guidance
though the interior light works when i open the door.
Old 01-18-2012, 01:35 PM
Re: i need guidance
Timster1,this might sound strange but bang on the dash a few times over the cluster. I've seen this work several times.
Old 01-18-2012, 02:11 PM
Re: i need guidance
Timster1 if that doesn't work typically the problem is caused by headlight switch, dash light dimmer switch a burned out bulb" I don't know if your car has one or several", fuse which you checked or possibly a loose connection that sometimes gets better when jarred. Let me know. good luck.
The Following User Says Thank You to jamesslcx For This Useful Post:
Timster1 (01-18-2012)
Old 01-18-2012, 04:22 PM
Re: i need guidance
i think its the switch to. thx
98 Ford Windstar GL Diagnostic Results - Need guidance Dizmatic Windstar 5 02-25-2007 04:07 PM
350Z and snow...need guidance mixter Nissan 350Z/370Z | Infiniti G35/G37 Coupe 3 12-29-2005 07:03 PM
Newbie needing guidance! Sticky Fingers Car Modeling 21 01-13-2005 03:42 PM
newbie needing guidance on swap dosterschill Engineering/ Technical 5 03-15-2004 01:10 PM
Need guidance. P1aGu3 General Discussion 1 02-09-2002 07:20 PM
