Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-02-2012, 02:10 AM
MsRael MsRael is offline
Unhappy 2002 crown vic Check engine light goes on when accelerates
When I accelerate over 50 the check engine light flashes and the car doesnt want to go
unless it catches it own speed.
Old 01-02-2012, 05:15 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2002 crown vic Check engine light goes on when excelerates
Does the engine seem to he shaking or feel like a miss is in it? If it does, have the codes read and see which cylinder is missing. You really need to have the codes read anyway. Most Auto Parts houses (Autozone, Advanced Auto, Pep Boys) will read the codes for free. Once the code is set, it will stay in the system for a long time. Please post back with the exact code number (P0304 or P0420). The codes will be like the numbers in parenthesis. Do not post what the person reading the code says it is. We need the number.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-02-2012, 10:35 PM
I Had somebody check the cylinders were fine but It does feel a bit shakky..
Old 01-03-2012, 05:52 PM
way2old's Avatar
TOKEN HILLBILLY
Did you have the codes read ? If the check engine light has been on, there is a stored code.
93 Ford Crown Vic Check Engine & Stalls txsouljaboy Grand Marquis 2 10-19-2007 06:04 PM
Check Engine Light Goes On & Off - Gas Cap? Sensor? Intriceight Engineering/ Technical 3 06-28-2007 04:24 PM
check engine light goes on and off BornToBeMe4 Villager 1 09-13-2005 10:51 AM
