Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-31-2011, 05:06 PM
95Silver345666 95Silver345666 is offline
Transmission skips second gear
I've got a '95 Silverado (automatic) that will only shift from 1st to 3rd. In fact you have to let off the gas for it to do that. It won't hit 2nd up or down and it never gets to overdrive. The fluid level is good.
Old 01-01-2012, 10:29 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Transmission skips second gear
Does it have reverse?
If no 2 or 4, but it has reverse, look for something failed in the area of the 2-4 band. The servo that operates this band is visible from outside the transmission, on the passenger side of it toward the front. Upon removing the clip that holds the cover in place (you could use Channelocks to 'persuade' the removal of the cover), you will see the piston setup. There are two pistons - one rides over the other - make sure the seals on both are good (there are three seals total). If everything looks OK, then the band itself might be toast. Did your fluid look good with a red to bright red appearance, no strong odor? You could also have a sticking valve. These transmissions (4L60E) have aluminum valve bodies that are known to wear out and cause problems.
If the reverse is also gone, suspect the reaction sun shell inside the transmission to be failed.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-01-2012, 10:44 AM
Reverse works just fine. The fluid looked good as well. The previous owner of the truck installed a floor shifter but the kind they installed doesn't allow me to manually shift to 3,2,1. I pull straight back to OD but when I drive it only hits 1st, let off the gas till it hits third then go. I'll check the pistons on the side but I've been told it may be shift solanoids as well? Also, are there electrical connections or something that may cause this? I have a suspicion that when the tranny work was done it was done by "less than professionals".
Old 01-01-2012, 11:43 AM
trannyman52 trannyman52 is offline
The retainer for the band may have sheared off,,,known to happen,,,there won't be burned oil to give the condition away,,,,,,just no 2nd --or --OD,,,,,cannot believe both pistons for band would fail,,nor both sol to fail at the same time.......
1993 Camry transmission skips 2nd gear mclark999 Camry/Camry Hybrid/Vista 0 07-31-2010 01:56 PM
05 silverado 5.3 transmission no second gear vancerj Silverado 4 08-29-2006 12:55 PM
Transmission skipping 2nd gear redhors66 Jimmy 8 05-22-2006 03:59 PM
Transmission, lost second gear Lumina98 Lumina 7 05-03-2005 01:24 AM
HELP! Transmission stuck in second gear! gthompson97 Off-Topic 14 12-23-2004 01:54 AM
Tags
chevy , problem , shifting , silverado , transmission
