Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 12-29-2011, 05:55 PM
Luweegy's Avatar
Luweegy Luweegy is offline
1999 Vette Headlights quit working.
I had them not come up and go on a couple of times.Then they have been fine for awhile.Now they won't do anything except if ya pull the high beam.Then they go on but don't come up. Stock bulbs. If I take controle with a Snap-On Solus I can make them do everything they are suppossed to do. Here are the codes I pulled out using the scanner in the dash.
B2284
B2285
U1016
U1064
U1095
They were all history codes. Thanx <Tom
Old 12-31-2011, 10:11 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 1999 Vette Headlights quit working.
B2284
B2285
U1016
U1064
U1095
A0-LDCM - Left Door Control Module
-B2284 Battery #2 Fault
A1-RDCM - Right Door Control Module
-B2285 Battery #2 Fault
B0-RFA - Remote Function Actuation
-U1016 Loss of Communication with PCM
-U1064 Loss of Communication with BCM
I couldn't find a code for U1095 but maybe you meant U1096 in which case is:
U1096 Loss of Communication with IPC
Hope this helps ya out on the codes...
As far as the headlight control, this sounds like the exact same problem my brother just ran into with his 03 Monte Carlo that the headlights only worked if you pulled and held the high beam. He had to replace the headlight switch/lever that mounts to the steering column and that fixed it for him. It's possible that the headlights not popping up for you is tied to the same problem. Especially since you are able to override the switch and they still function normal. That tells me that the headlight motors and bulbs and wiring is fine... I'd pull a new headlight switch from a junkyard and give that a go. Good luck!
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 12-31-2011, 01:45 PM
Luweegy's Avatar
Thanx for the help,Those door codes cam from putting a window motor in it I bet last summer.The other code is right loss of comunication with insturment panel.Funny thing is the other nite when it was dark out.The lights came on and wouldn't go off till I rotated the headlight swith.Even though the car had been turned off for 10 minutes.i'm thinking headlight switch too.
Cutlass supreme headlights quit working sxymama1014 General Discussion 7 04-22-2009 05:06 PM
automatic headlights quit working crazy Jim ES300/ES330/Windom 0 02-13-2007 06:03 AM
88 k2500 headlights quit working khwils C/K 2 05-31-2005 10:36 PM
Headlights quit working (Fuse Blows Always) sk7 Metro 1 03-04-2005 09:38 PM
low beam headlights quit working knewman23 Beetle - New/New Beetle Convertible 4 06-04-2004 12:59 PM
