Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 12-29-2011, 12:58 PM
gikris gikris is offline
Sensors going off
Bought a 2005 Ford Explore xlt and 3 sensors keep going off for no reason door oil and low tire has any one or does any one know how to fix diy
Old 01-22-2012, 05:20 PM
joemffields joemffields is offline
Re: Sensors going off
Your tire sensor is prolly going off because the pressure in one or more of your tires is incorrect, check the recommended psi and correct it, it should tell in the owners manual, and you might have to reset the sensor, also should tell in the owners manual. Your oil sensor could be going off because of too high of pressure, to low of pressure, or that it's time to change it, if you have already changed it and it's still on then you might have to reset it, also should tell in the owners manual. As for your door sensor, check and make sure all of the door are shut securely, if that doesn't work you might be getting a bad connection with one of the door sensors. make sure they are connected, check for cut or damaged wires in and around all of your doors. hope that helps
Traction off and ABS light will not go off dallen13.1@netzero Intrepid 0 10-05-2007 02:26 PM
Alarm going off, can't shut it off... LuthierJr Bonneville 5 06-26-2006 07:10 PM
I'm going to go off the deep end..... Pick Stress Release 17 06-16-2003 05:57 PM
Help! 91 Escort - when using turn signal, tail lights go off! ritchiegp Escort 1 03-16-2003 01:41 PM
I am going off race car models!!! Guiddy Car Modeling 3 11-27-2001 07:48 PM
