Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-28-2011, 12:59 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Clutch fluid leak
Hi all
My son has 1995 Eclipse, 2.0 engine.
His clutch started acting up and we, based on our previous experience with 94 model we used to have, bled the clutch cylinder.
It worked for couple months, then 2 days ago clutch was lost again, as in no resistance to pedal.
I found that master clutch cylinder was almost empty. Of course, air got in and lead to lost clutch.
Refilled and bled again.
Took a good look at the plumbing. There appear to be no obvious leaks and it seems to be a very simple system - one rubber hose from canister to MC and then metal line straight down to clutch cylinder. It all looks intact and dry.
Where does the fluid go? Is it possible to leak internally, from clutch cylinder into the transmission housing, as there's drippage from the transmission housing bell down, dead at the lowermost point of it, where's mounted to the engine. Might be main seal too.
Any suggestions? We had to do same to our 94 Eclipse, makes me believe it's a common issue?
Thank you.
Old 12-28-2011, 01:37 PM
ukrkoz's Avatar
Re: Clutch fluid leak
found it. leaks on the firewall, inside the car, from clutch master cylinder. have new one ordered, 20 bucks..
Old 12-29-2011, 09:54 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Glad you found the problem. Very simple system, usually pretty easy to see what the problem is. Also I would consider changing the rubber line at some point as that will be the next part on the system to go out. They dry rot pretty easily and will of course cause problems. On my 95, it was getting brittel and was only a matter of time before it started leaking.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-29-2011, 12:39 PM
ukrkoz's Avatar
just swapped it out. considering I'm 6'5'' and hands are size of bread loafs, 'twas fun to do.
rubber line is fine. car is old age but has very little miles for the year.
Old 12-29-2011, 04:25 PM
steviek's Avatar
steviek steviek is offline
yea i had to swap in a SS line as well.
My master went too.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
2000 Windstar transmission fluid leak olopezm Windstar 16 09-17-2010 08:51 PM
Clutch Fluid Leak? leroge Wrangler 3 01-31-2009 02:43 PM
Clutch Fluid Leaking Out ! DOCTORBILL Cherokee 3 02-12-2008 09:09 AM
clutch fluid leak X2Xtreme360 3000GT/Stealth 24 02-07-2007 01:16 PM
Clutch fluid leak question fadeaway Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 10-19-2004 09:46 PM
