Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-27-2011, 07:52 PM
chevelle_ss_69 chevelle_ss_69 is offline
Trans or engine problem??
As the weather has been getting colder my grand cherokee has been getting worse. Its a 99 with a 4.0 4wd laredo. In the morning when the vehicle has sat over night, on the way to work the first few stop lights im at, foot on the brake, the rpms begin bouncing down to about 800 and then come back up, sometimes the trans feels light its trying to make the vehicle buck forward even though ive still got my foot on the brake, other times it just doesnt seem to want to go for a second and then kicks in. The vehicle only seems to do that stuff when its cold, after its warmed up itll still do it at a light, the rpms dropping and coming back up, but the trans doesnt seem to flip out like before it got to temp. Any ideas what to look for or where to start?? theres zero codes so says the snap on scanner, and everything seems to look fine from that aspect
Old 12-27-2011, 11:06 PM
CL8 CL8 is offline
Re: Trans or engine problem??
My older vehicles also have been more sluggish in cold weather.
When one of my vehicles had similar problems it was the fuel line either the pump or filter needed replacing, can't remember which.
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
Old 12-30-2011, 10:48 PM
Raimundo Raimundo is offline
Check transmsision fluid level when hot engine, I mean let warm up for several (may be30 mins.) then check level and quality( red clolor, viscosity) of fluid ( in PARK).
Old 01-01-2012, 12:02 PM
trannyman52 trannyman52 is offline
fuel pump failing sounds more likely to be the problem,,,,,though poor battery connections,,poor battery,,weak alternator will also give engine rpm issues.....
Old 01-02-2012, 03:44 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
How about your plugs? If you haven't replaced your spark plugs in the last 30000 miles, it's probably time. You said the issue started when it got cold. Any weakness in the electronics will usually show up when the temperature drops.
Also, how many miles do you have? On the '99 sometimes the Crankshaft Position Sensor can cause odd shifts, lurching, and engine anomalies. On my '00, it would shift into different gears, idle oddly, and quit a couple times on me on the highway. If you're over 90k miles then the CPS might be your issue. The only codes I got with mine was "multiple misfire". There was no code for the CPS...at first.
edit: as to the engine/transmission question: does it do it when you're at a stoplight, in neutral? Agree with other poster suggesting to check fluid level....although the 00 suggests (on the trans dipstick) to check with engine hot, idling in neutral.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
97 4L60E Trans problem mavbeacon Silverado 9 10-07-2012 12:28 PM
79 trans am w/ engine problems, confused 19 year old, timing question? TurboLaser4G63 Camaro Discussions 8 06-27-2006 11:22 PM
Swap engine and trans to an S2000 engine and trans... basslover911 Integra 6 09-27-2004 01:02 PM
