Old 12-24-2011, 06:43 PM
not_scared05 not_scared05 is offline
96 cavalier messed up again
ok my cars check engine light started flashin yesterday so i hooked a innova 3160 scanner to it and got a po302 code but the I/M monitor icons CAT, O2S, HTR, EGR, AND EVA just keep flashing. what should i do about that because i know it has a cyl 2 misfire but im not made of money so i can just go from injectors to fuel pump just replacing parts.
Old 12-27-2011, 06:21 AM
autojoe autojoe is offline
Re: 96 cavalier messed up again
get a spark tester and hook to that cylinder and see if good spark.check plugs and wires.could be a dirty or bad injector.could also be compression related......burned valve ect.
The Following User Says Thank You to autojoe For This Useful Post:
not_scared05 (12-27-2011)
Old 01-05-2012, 02:32 PM
ok just did a compression test cyl.1=180 cyl.2=135 cyl.3=175 cyl.4=174 and cyl. 2 held its compression so other tham it being a burn valve and needing to be replaced ( just rebuilding the whole top end) what other things should i check for. lookin for a cheaper and less time consuming fix if at all possible.but its still just throwing out the PO302 code only
Old 01-05-2012, 03:01 PM
tempfixit tempfixit is offline
I would do another compression test on # 2 this time squirt some oil into the clyinder, if the compression increases the rings a leaking if not you know that it is in the valves or head area.
Old 01-05-2012, 08:33 PM
agree with tempfixit.......
Old 01-06-2012, 01:23 AM
DeltaP DeltaP is offline
On that unit they'll continue to flash until you've driven the car enough to complete a 'drive cycle'.
Old 01-06-2012, 09:29 AM
ok ill get the gauge again and re do the compression test. and how long does it take for the " drive cycle" i have put about 50 miles on it since i ran the scanner on it
Old 01-06-2012, 09:42 AM
Tech II Tech II is offline
"On that unit they'll continue to flash until you've driven the car enough to complete a 'drive cycle'. "
Not really.....it flashes because the car is misfiring so bad, that it can cause cat damage.....for example, if you start the car, and it is flashing, that misfire is real bad.....or you may start the car, it doesn't flash until you put it in gear or under a load....if under a load it flashes, by lightly using the accelerator pedal, it will stop flashing....has nothing to do with a drive cycle, has to do with how bad the misfire is in that moment in time....
Old 01-06-2012, 10:48 AM
the class 2 missfire that can cause catalyst damage on older cars the pcm will flash the mil.....on newer cars pcm can disable injectors.....it should have been like that before so people would not drive it......as far as the scan tool flashing like stated...i hooked a innova 3160 scanner to it and got a po302 code but the I/M monitor icons CAT, O2S, HTR, EGR, AND EVA just keep flashing. must be the scan tool.I heard this before.I have never used before.
Old 01-07-2012, 03:34 PM
viggy58 viggy58 is offline
the flashing check engine light means that it has a severe misfire.
the flashing lights on the scanner means that the car is in failsafe mode, and those tests (o2, etc) cannot be performed until the misfire is cleared and the car is drivin a full drive cycle. sounds like bad plugs/wires, or a failing coil pack. most auto parts places can bench test the coil pack and the plate the sit on...
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 01-08-2012, 10:34 AM
I was refering to the flashing icons on the Innova 3160 scanner.
Old 01-08-2012, 10:37 AM
2001 Cavalier hizkid42 Cavalier Problem Diagnosis 2 03-07-2009 09:20 AM
1996 Cavalier Douglas91 Cavalier Problem Diagnosis 7 02-21-2009 07:53 AM
mystique mess again Moriah Mystique 0 08-11-2005 06:44 PM
94 Cavalier n Cavalier z24's kamakasi Performance 4 02-17-2005 09:10 PM
will a 98 cavalier engine work in a 97 cavalier rs? lyndalla Cavalier 4 12-12-2004 12:01 PM
