Old 12-24-2011, 03:52 PM
Dmurphy05 Dmurphy05 is offline
2003 Town and country Horn Not working
I have a problem with the horn on my 2003 town and country. The horn will not work from the remote door locks or the steering wheel. I bypassed the relay and it is ok from there. Is there any way to get a diagram for this circuit?
Old 12-24-2011, 04:49 PM
tempfixit tempfixit is offline
Re: 2003 Town and country Horn Not working
Sign up for free at autozone.com for the repair manuals. Hopefully they will have the diagram.
Old 12-24-2011, 05:51 PM
Already tried that. they don't have them.
Old 12-24-2011, 10:28 PM
Try this link if it does not work send me a private message with your address and I will send the diagram as a attachmnet;
http://arrc.ebscohost.com/searches?c...ssc%2Fp5_horns
hope this helps
Old 12-25-2011, 05:15 AM
hope this helps
I tried but it asks me for a name and password. I am sending a PM now.
Old 12-25-2011, 08:21 AM
Have you checked if your local Library has EBSCO? If so look for the AUTO REPAIR REFERENCE CENTER (ARRC).
PS: I sent you a email to address given, let me know if it worked.
Old 12-25-2011, 09:12 AM
Thank you, It worked fine. If you know? where is the Horn switch? what is it's purpose?
Old 12-25-2011, 09:16 AM
I think the horn switch is when you press the horn button on steering wheel. Does your cruise control work? Possibly the clockspring, if so check to see if there is lifetime warranty on it.
Old 12-25-2011, 09:22 AM
The clockspring seems to be ok. The cruise works fine. I am wondering if the horn switch is for the remote locks and panic button. I have to locate this and the front control module to test them.
Old 12-26-2011, 02:55 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The Front Control Module (FCM) is that silver box secured to the front of the fuse box (IPM) by 4 bolts. Disconnect the negative battery cable before removing it. From your symptoms it sounds like the horn pad switch and clockspring are good but the FCM is not setting the ground to the relay coil. I would say either the contact for the ground output at the FCM is corroded or the FCM is bad. The FCM/IPM connection is a known problem area for corrosion or poor connection.
If the clockspring or horn pad switch was bad you would still get the horn to sound when you locked the doors with the key fob.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 12-26-2011, 05:37 AM
Thank you. I am going to try to dig into it today. The horn will not operate from the fob or wheel. I bypassed the relay and it is ok there. I guess I will check those connections at the FCM.
Old 01-02-2012, 07:48 AM
had to take it in. Dealer found a problem in the fuse block.
Old 01-02-2012, 10:15 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Makes sense. Thanks for posting the fix. Glad to hear you're starting off the year with a working horn.
Old 01-02-2012, 01:26 PM
Yes, it was in the plug wiring between the FCM plug and Horn relay.
2003 Town and Country rubyms Caravan | Voyager 5 01-25-2007 06:52 PM
2003 Town and Country will not start dunndeal55 Caravan | Voyager 6 01-02-2007 06:28 PM
2003 Town and Country desertdiggler Caravan | Voyager 2 09-24-2006 11:26 AM
00 Town and Country- intermittent speedometer working/does not start immediately starkon Caravan | Voyager 3 09-29-2005 10:39 AM
2003 town and country, electrical nightmare dukeyray Caravan | Voyager 3 05-26-2005 05:54 AM
