Old 12-23-2011, 06:28 PM
ellev8or ellev8or is offline
92 PA Automatic Leveling System
Is it a bad idea to disconnect the Automatic Leveling System on a 92 PA? If not I would like to disable it because it constantly drains my battery. This is my second PA and I've never had this issue. Every morning I discover the battery is drained and the battery and alternator is good; I've had them checked.
A few instances after parking my vehicle I exited and timed how long the ALS takes to adjust in a level, incline and decline position, while parked on the street, and it was about the same time; I forgot how many minutes. But when I stayed in the car it took longer I believe. How long does that pump suppose to run?
Anyway, I would like to disable. Please tell me how.
Thanks
Old 12-23-2011, 09:24 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92 PA Automatic Leveling System
Pull fuse #12 in the fuse panel under the drivers side dash to disable ALC. Evidently, you have a leak in the rear strut bladders. New struts are required to eliminate the leaks.
The Following User Says Thank You to HotZ28 For This Useful Post:
ellev8or (12-24-2011)
Bonneville Automatic Load-Leveling System bholthaus Bonneville 4 03-06-2011 05:09 PM
Automatic Level Control Isnibs Aurora 10 09-22-2010 11:33 AM
Automatic Leveling Rear Shocks bocoogto Roadmaster 13 04-18-2006 04:01 PM
Automatic leveling 307 Yukon 1 10-31-2004 04:06 PM
95 Roadmaster Automatic Level Control akreuz Roadmaster 2 02-08-2004 12:54 PM
