Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-23-2011, 03:02 PM
dont_forget dont_forget is offline
LS V8 Engine Problems
I have a 2001 LS V8 and recently I've noticed it cut out a little bit when accelerating at full throttle. I am not sure what could be casuing this but I would like to get it repaired because this summer I am planning on a lot of travel and am going to have to rely on this car. While I'm accelerating it seems to shortly plateau at a cretain RPM and then it gets power and accelerates again all without any chinge in trottle from me. Any feedback is appreciated.
Thanks
I'm thinking fuel pump but just want to make sure...
Old 12-23-2011, 05:12 PM
joegr joegr is offline
Re: LS V8 Engine Problems
Before you pull the fuel pumps (yes, there are two), you should change the fuel filter. It's behind the guard behind the driver's side front wheel.
Also, the most common problem for the LS V8 is partial failure of one or more ignition coils.
Old 12-24-2011, 08:36 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Agreed. If you have a scan tool that can access the "component parameters" or PIDS you should be able to identify if there is a cylinder or two that is/are misfiring, even if the misfire counts are not yet high enough to trigger a diagnostic code.
The fuel filter is a routine maintenance item, so even if it is not the problem, it will be money well spent to replace it. They are often overlooked as part of a tune up, especially since they are not out in the open on these cars.
-Rod
Old 12-24-2011, 07:28 PM
Thanks for the input guys. I recently drove a little over a hundred miles on the interstate and noticed when i would give it extra gas to go up hills it would start to stutter a little and the check engine light would turn on. I'm assuming the ignition coils then. I've already replaced the one in cylinder 2. Any idea where I can get a scan tool to see the information from the previous post?
Old 12-24-2011, 09:21 PM
shorod's Avatar
SHO No Mo
Since your check engine light came on, you won't need a tool that can access the component parameters. Just a standard scan tool to read the codes should reveal which cylinder or cylinders is/are misfiring.
The one that I know could access the component parameters is the OTC Genisys.
-Rod
Old 12-25-2011, 12:09 AM
The problem is the light didn't stay on. Can I still read why the light came on?
Old 12-25-2011, 07:28 AM
shorod's Avatar
SHO No Mo
Yep, with OBD-II if the issue was present long enough to trigger the Check Engine Light (CEL) a code will be stored for several cycles, even if the issue is not currently present. Often your local auto parts stores will offer a service of reading diagnostic codes at no charge. You'll want to get the actual code number though, in the form of P0123, rather than the salesperson's interpretation of the code. Then post the code back here.
-Rod
Old 12-26-2011, 05:47 PM
Okay so I just got back from the parts store and I am getting code P0305 for what they said was cylinder 5 misfire. Would that be ignition coils?
Old 12-26-2011, 07:51 PM
95+% of the time, yes it is. Remember to change the #5 sparkplug as well. (Bad coils damage sparkplugs, bad sparkplugs damage coils, rinse and repeat.)
#5 is at the front of the engine on the driver's side.
Old 12-26-2011, 11:25 PM
Thanks a lot for your help joegr and shorod I really do appreciate it. I just have one more question. Where do you recommend I buy the ignition coil? (are they cheaper online)
Old 12-27-2011, 08:17 AM
Personally, I get them from a Ford dealer on line that gives good discounts, so the OEM coils are around $50 instead of $90. The newest revision of the coils seems to be pretty reliable. I think that experiences with e-bay coils are hit and miss.
Old 12-27-2011, 08:52 AM
shorod's Avatar
SHO No Mo
Pun intended?
-Rod
Old 12-28-2011, 07:11 PM
RJLipscomb RJLipscomb is offline
I bought my new COPS at Autozone. I think they were $45 each? So far so good.
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-14-2009 11:26 PM
Tranny problem or engine problem??? pat8424 Grand AM 5 03-13-2009 07:35 PM
engine problems. always engine problems. alwaysproblems Fiero 2 04-09-2007 01:56 PM
93 Cutlass Supreme Engine Questions/Big Problem caused by engine flush swhistle Cutlass Series 2 03-01-2004 09:43 PM
