Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 12-22-2011, 06:33 AM
dorlow dorlow is offline
low oil pressure when first started car?
Ok, I'm looking at problems really closely on this 2006 Montana SV6 van right now. We have a warranty that's expiring in a few thousand miles. Our tranny went out so we just got that rebuilt for the $100 deductible a few days ago. Got lucky on that one.
When I started the van to pull it into our garage yesterday, for a few seconds, the DIC displayed "Low Oil Pressure" for a few seconds and went away. The only time I ever see that message is immediately after I change the oil. But the van hasn't had an oil change for about 1500 miles.
Is this something I should get it back into the dealer to fix before the warranty expires? Or is it normal for once in a while to show that message on a start?
Old 12-22-2011, 07:02 AM
snshddog snshddog is offline
Re: low oil pressure when first started car?
I would change the oil filter. I have seen oil filters go bad and cause that. At the same time you can cut open the old filter so see how much debris is in it to see if bearings or such are coming apart. Filters are cheap engines are not.If the dealer wont do it then for the cost of a filter just get it done anyways so you know.
Old 12-22-2011, 09:29 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Check the oil level to make sure it is where it should be. Also, what was the temperature when you started the van? If it was cold the oil may be too heavy for the temperature and should be changed to a lighter weight. Finally, I agree that the oil filter may be a problem as it may be partially plugged or the anti-backflow valve may no longer be working.
If all of the above are normal and the issue doesn't resolve itself after the filter change take it to the dealer for a diagnosis.
Old 12-23-2011, 08:52 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
If you do go into a dealership for a diagnosis, please let me know through a private as I would like to follow up with them (and you) to make sure that everything is taken care of.
Happy Holidays,
Sarah
GM Customer Service
Old 12-23-2011, 09:07 AM
DeltaP DeltaP is offline
My daddy used to say that oil and filters are the cheapest thing you'll ever put in your engine!
If the oil level and viscosity are correct for your current climate and its been changed recently like you say then the guage pressure switch might be sticking due to the temperature outside.
My '02 Mountaineer used to do that whenever I was traveling in a cold climate.(like in the 30's). Except it would stay on till the engine warmed up! I put a manual guage on it to verify oil pressure was ok at start up. Then changed the guage sender. Problemo adios.
Old 12-23-2011, 02:26 PM
Tech II Tech II is offline
I agree with DeltaP.....remove the sender and attach a mechanical gage to check the pressure.....
Old 12-25-2011, 11:53 AM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: low oil pressure when first started car?
I'd agree with replacing the filter. I had this problem with FRAM and the many "after market" filters they do for other brands (Canadian Tire - MotoMaster being one).
The design flaw is that the back flow preventer built into the filter becomes inadequate after about 500 miles. The back flow is supposed to prevent the filter from draining (horizontal mounting filters typically) back into the oil pan, but the preventer weakens and loses its ability to keep the filter charged with oil between runs.
Result: every start is a cold start similar to draining and filling with new oil and replacing the filter.
I've had better success at NAPA, particularly with WIX filters, and Hastings are good too. Like most things, you get what you pay for, but I think a good filter should still cost about $5.00, no more.
If I had my way, every GM car I ever owned would be a Chrysler!!!
Low Oil Pressue in 2004 Yukon XL Denali with 72000 miles DenaliDB Yukon 0 06-12-2011 09:08 AM
2003 blazer, low oil pressure intermittent tjmjr72 Blazer 2 03-15-2010 09:32 PM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
Low Oil Pressure When Cold Outside estone4009 C/K 1 02-13-2004 03:42 PM
Low oil pressure when idle mtmacdaddy Sierra 3 01-14-2004 05:39 PM
