Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-14-2004, 10:03 AM
mtmacdaddy mtmacdaddy is offline
Angry Low oil pressure when idle
I own a '96 GMC 4.3l Sierra with about 120k miles. When sitting idle my gauge shows little to no oil pressure at all. When I give it some gas then the pressure shoots up to about mid-point and lowers down to about 1/4 total when on the freeway. Is this something to be worried about? It burns a little oil but there are no leaks and no engine noise. It runs great. I just don't want to do any damage to it! Any help is appreciated!
Old 01-14-2004, 03:55 PM
bvanemon bvanemon is offline
I have a 93 GMC my neigbhor has a 94 , both with the 4.3, both are well over the 135,000 mark. His was doing the same thing so I tested pressure with a mechanical gauge. It fell well within the normal range, I replaced the sending unit still the same thing, so I would assume that the dash gauge was or is at fault. Still a mechanical gauge is the best way to make sure.
Old 01-14-2004, 04:08 PM
hypersport190 hypersport190 is offline
Send a message via AIM to hypersport190
Re: Low oil pressure when idle
My '94 has over 150,000 on it and the 5.0L engine. It also acts the same way. I have no leaks and burn a little oil and would say it is normal.
Old 01-14-2004, 05:39 PM
dash gauge heh? I replaced the sending unit and that was not the problem so I will try the mechanical gauge and see what I get. Thanks!
2003 blazer, low oil pressure intermittent tjmjr72 Blazer 2 03-15-2010 09:32 PM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
oil leak and low oil pressure at idle mrbussells Eclipse Problem Diagnosis 0 10-15-2008 07:20 PM
Low oil pressure at idle, fine when driving mixedgrip Rodeo | Passport | MU 11 12-30-2006 01:20 PM
Low Oil Pressure When Cold Outside estone4009 C/K 1 02-13-2004 03:42 PM
