Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 12-21-2011, 07:01 AM
timhahn timhahn is offline
2006 Dodge Stratus wont start
My car died at a stop sign and would not restart. It had the original stock battery in it and tested bad so I replaced it and still did not start. We also got alternator tested and tested good. We got error code p0340 which is camshaft position sensor and replaced that still didn't start. We took it off to see if the cam would turn while cranking it did not also took the timing belt cover off and cranked engine it did not turn either. I am sincerely stuck and could use whatever help you can give me.
Old 12-25-2011, 08:02 PM
peterjon1 peterjon1 is offline
Re: 2006 Dodge Stratus wont start
Most likely your timing belt has stripped the cogs on it. Replace timing belt.
Sometimes the little voices in your head have really fun ideas.
Old 04-07-2013, 07:58 AM
spike1269 spike1269 is offline
it is def the timing belt.. I myself have never seen one just stop working or snap or wear the teeth off of.. but I have heard of it happening a lot.. but if the motor is indeed cranking, and the top of the motor isnt turning, then its the belt or tensioner, I had a water pump go bad on an intrepid and got the tensioner wet and it fell apart when the bearing locked up, and belt let go.. replaced the tensioner and bely while in there after the water pump, and went TDC on both heads and crank, started right up and was perfect till I sold it.
2004 Dodge Stratus R/T Bogging down while accelerating brice0829 Stratus 2 05-28-2013 05:34 PM
2006 dodge stratus gmh56 Stratus 2 12-18-2010 09:43 AM
03 Dodge Stratus Sxt NewBuyer21 Stratus 0 11-27-2009 06:37 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
