Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 12-19-2011, 05:47 PM
half-fast half-fast is offline
Mystery Problem Solved 1993 TC
Several intermittent problems solved... including random stalling and weird shifting.. the vacuum T on the rear passenger side of the engine was rotted and had a 1/16" hole in it. It was also collapsing when it got hot. Dorman #47072 from O-Reilly Autoparts is the fix. They had it in stock... everybody else had to order it. Just a heads up... I chased this intermittent gremlin for quite a while. Hope I save somebody else the aggravation.
Old 12-19-2011, 06:26 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Mystery Problem Solved 1993 TC
Nice!
Just to clarify, that rubber tee can be found between the PCV valve and the intake 90 degree adapter and is a common failure item in 91-94 (some early 95 models have been reported) 4.6L engines. It will cause a vacuum leak and several idling problems.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 09-23-2012, 09:56 AM
danielsatur danielsatur is offline
A smoke test is easy + safest way to find a vacuum leak, Do Google ''Youtube Auto smoke test''
ELC-3 year mystery finally solved! Loekee75 Park Avenue 2 11-23-2007 01:51 PM
Toyota 1993 vibration, gas padal freeze. Problem solved. Thanks for help Leo190 Camry/Camry Hybrid/Vista 3 05-17-2004 05:19 PM
