Old 12-18-2011, 11:57 PM
iceman3032003 iceman3032003 is offline
97 S-10 replacing the fuel injectors
thanks for your help
Old 12-19-2011, 08:23 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 S-10 replacing the fuel injectors
Originally Posted by iceman3032003 View Post
I have a 97 S-10 p/u ext. cab it has a 4.3 W at 150,000 miles running very ruff I was told to replace the fuel injectors. My first question before I buy them and then replace them is this, it appears that the fuel pump regulator is part of this unit. If so does it have a vacum line on it since I have seen and old one and it does look like a line is connected to it. Agin I was told it does not have a vacum line to it and a new one is converted to not need one, so which is it yes it has one or no. I cannot see where a line runs through the upper intake to go to it. Yes I would be smarter to let an experienced mechanic fix this, but I am retired and want to work on it myself. Over the years I have rebuilt engines but those were carbuator no computer stuff just simple and to the point good ole days LOL. I hope to hear from some of you experienced 4.3 mechanics thanks.
The fue pressure regulator inside plamtium does not use a vacumn line.
Vacumn is applied from vacumn inside intake.
But I would do some proper testing before saying injectors are bad or replacing them.
Most good engine scanners have a bult in injector test.
Have you checked for proper fuel pressure?
You have to have good fuel pressure for injectors to work right.
MT
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 02:06 PM
Should I replace the Fuel Injector? sebryce Blazer 1 04-30-2006 11:42 AM
Replacing the fuel injectors on the 3SGTE Im JDM Yo MR2/MR-S 0 02-01-2005 03:36 AM
1991 S-10 4.3L Fuel Injectors not working krumrei S-10 8 06-13-2004 12:02 AM
Thanks For The Fuel Injector Help TOENY1967 Blazer 0 03-23-2004 12:56 AM
