Old 04-04-2004, 02:42 PM
krumrei krumrei is offline
1991 S-10 4.3L Fuel Injectors not working
Ok,
Here is the deal.
I replaced the fuel pump, relay, ICM, Coil and the Oil Pressure switch.
Everything is getting power, and oh, I replaced the Fuel Regulator kit as well.
The injectors get power, but they do not squirt fuel.
I looked at the scematic and I cannot see anything but the ECM ( computer) that controls this.
Am I missing something other than the last thing of replacing the computer in the thing?
PS. I do NOT have any blown fuses, checked that already.
Any help PLEASE
Paul Krumrei
Grand Rapids, MInnesota
Old 04-04-2004, 02:57 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
The injectors have +12v whenever you turn the key to run or start.
How they 'flash' is that the ECM supplies a ground at proper times.
If you are not then either the ECM is bad, or it is not being told when to flash. The ECM picks up an RPM signal from the Ign system - and it might not be.
Try talking to the ECM with a scan tool and see if it is aware of RPM while cranking.
Old 04-04-2004, 03:06 PM
Re: 1991 S-10 4.3L Fuel Injectors not working
Hey there again!!
I replaced all the ignition parts and still nothing.
I am assuming that when you say talk to the ECM, to plug a computer into it and see if the thing reads the RPM level.
I think I am going to replace the ECM, it only seems to be $100.00.
I cant think of anything else.
I know there is NO pulse to the System, as I checked it with a niod light.
So, the only thing that I can see in the book is the ECM controling the pulse not working correctly.
Thanks again pal, your wonderful to get help from!
Paul
Old 04-04-2004, 07:10 PM
Re: Re: 1991 S-10 4.3L Fuel Injectors not working
Does Anyone Know Where To Get A Cheap Ecm?
Old 04-08-2004, 11:23 PM
Re: Re: Re: 1991 S-10 4.3L Fuel Injectors not working
Still scared to waste money on the ECM is anyone out there know what might be my problem?
Thanks!
Old 04-08-2004, 11:25 PM
I have one for a 93 K1500 with 4L60 and 3.42 rears.....should for the most part fit
Old 04-10-2004, 07:42 PM
What is the part number it should start with 16 something and end in either 455 or 288?
I need the 288 ( california ) ecm. I think? or would it work if I took the PROM chip out of mine and replaced with yours?
What you asking for it?
Thanks!
Old 04-20-2004, 09:22 PM
bwtpwr bwtpwr is offline
Send a message via Yahoo to bwtpwr
if u checked injector harness with noid light n no pulse ur ecm is faulty
Old 06-12-2004, 11:02 PM
oswarped oswarped is offline
Send a message via MSN to oswarped Send a message via Yahoo to oswarped
Was there a solution found for this problem?
I see the last post was in April.
Ok,
Here is the deal.
Any help PLEASE
Paul Krumrei
