Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-16-2011, 03:58 PM
truc0011 truc0011 is offline
2001 Ram 2500 Pickup - Fuel Pump
To replace the fuel pump - should I drop the tank or remove the bed? What is easier?
Old 12-16-2011, 06:05 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2001 Ram 2500 Pickup - Fuel Pump
Gasser or diesel?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 12-16-2011, 06:38 PM
Originally Posted by Chris Stewart View Post
Gasser or diesel?
5.9 gas, short box extended cab (34 gal tank)
Old 12-17-2011, 07:27 PM
AF - Advisor
I've read one is as easy as the other except you can inspect the fuel and brake lines for corrosion if you pull the bed.
2001 Ram 2500 -- Transmission fluid leak truc0011 Ram Pickup | Ram SRT10 1 05-25-2010 12:03 PM
Ram 2500 Quadcab Fuel Mileage radracer524 Ram Pickup | Ram SRT10 4 09-09-2005 11:49 AM
Ram 2500 gas fuel filter dardena53 Ram Pickup | Ram SRT10 4 02-13-2005 10:34 PM
2001 Ram 2500 cummins diesel littlebit Ram Pickup | Ram SRT10 1 01-25-2005 12:45 AM
1999 2500 needing fuel pump? write off Ram Pickup | Ram SRT10 0 08-18-2004 11:50 PM
