Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-27-2009, 11:12 PM
truc0011 truc0011 is offline
2001 Ram 2500 -- Transmission fluid leak
Hi there,
I just got a 2001 Ram 2500 (5.9 gas) which has a very small tranny fluid leak in it. The fluid DOES NOT go through a cooler in the radiator, it has an external tranny oil cooler in it. The fluid appears to be coming from the lower driver side corner of the cooler (it is hard to see since it is between the radiator and the ac condensor) I read in the manual that there is a tranny fluid thermostat, could that be where this fluid leak is coming from? Maybe a bad gasket or something?? Just thought I'd check to see if there are any common issues like this before I pull it apart.
Thanks!
Old 05-25-2010, 12:03 PM
Re: 2001 Ram 2500 -- Transmission fluid leak
Originally Posted by truc0011 View Post
Hi there,
Thanks!
Has anybody removed and replaced their external tranny cooler, what is the easiest way to do this? Take the radiator out first?
