Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-15-2011, 11:06 AM
johnaschmitt johnaschmitt is offline
verify crank bolt torque spec 1999 3.1
Hello folks.
1999 Malibu LS 3.1 V6 type "J"
Just finished changing the crank pulley. The only spec I could find in the Haynes manual that sounded like a crank pulley bolt was listed as "Vibration damper bolt-- 76 Ft-lbs."
Seems a bit low compared to other vehicles. Could someone verify the torque spec please? I know the shaft is keyed, but I don't want this thing getting away.
Thanks a lot.
Old 12-15-2011, 04:20 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: verify crank bolt torque spec 1999 3.1
76lbs ft. is correct.
Old 12-15-2011, 08:30 PM
Thank you very much.
side note, I can't believe how much smoother and quieter the motor is now. This thing must have been on the way out for a while.
valve cover bolt torque spec greg9034 Cavalier Problem Diagnosis 2 05-12-2005 11:20 AM
flywheel bolts torque specs edwin nieves Caravan | Voyager 0 04-30-2005 04:24 PM
zc head bolt torque specs slipknotcraig133 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 01-22-2005 03:19 PM
Opinion: Water Pump Bolts Torque Spec avatar307 LeSabre 7 10-31-2004 10:22 PM
95 2.2L Vtec rod bolts & Crank bolts torque specs PVR32 Prelude 0 06-28-2003 03:29 PM
