Old 05-10-2005, 02:09 AM
greg9034 greg9034 is offline
valve cover bolt torque spec
I recently noticed oil deposits forming around my spark plugs. I asked a local mechanic, he stated that my valve cover bolts might be loose. Is this what may be causing the deposits? If so what should I torque them to?
Old 05-10-2005, 07:30 AM
hourang hourang is offline
Re: valve cover bolt torque spec
not sure if thats the cause, im sure you could tell if it was leaking. cover bolts are 89 in/lbs, thats inch lbs not foot pounds. you really only need to tighten them snug. i would replace the gasket.
-jeff
1995 Pontiac Sunfire 2dr auto
205,475miles and counting...
Old 05-12-2005, 11:20 AM
I torqued the bolts, they were pretty loose. This did the trick. No more oil all over plugs.
Thanks
