Old 12-13-2011, 10:43 AM
emingin emingin is offline
98 Blazer replace starter
I need to replace the starter in my 1998 Blazer, 4wd, 4 door, LS. I've read online everything from it taking 1/2 hour, to all day. Some say the motormount has to be removed and the engine jacked up to get it out, others say that's not the case and that it's a breeze.
Who's right? How hard is it?
Thanks
Old 12-13-2011, 12:33 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 98 Blazer replace starter
I have'nt done one in a while, but I remember them being a pretty simple repair. Don't forget to disconnect the battery!
Old 12-13-2011, 05:57 PM
viggy58 viggy58 is offline
very easy job in my 2wd. dunno if the 4wd is much different though...
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 12-15-2011, 08:52 PM
old_master's Avatar
Advisor/Moderator
Chilton flat rate for 4WD starter replacement is .6 hours and add .3 if it has a skid plate, (under an hour either way).
You have to know how it works,
to figure out why it doesn't.
Old 03-04-2013, 02:13 PM
jacko165 jacko165 is offline
jack up passenger front wheel take it off,there is a inspection flap on the wheel arch take it off the starter is just below
Old 03-05-2013, 05:34 AM
rhandwor rhandwor is offline
Without a lift and proper tools it will be at least double.
Unknown alarm system replacing remote Football42008 Engineering/ Technical 6 01-17-2010 10:44 PM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
replacing starter on 4x4 99 s10 blazer biketucson Blazer 2 12-27-2005 05:42 AM
Replace Starter on 4.3l 4WD Blazer melon_medley Blazer 8 12-17-2004 01:59 PM
Replacing starter need help! Bencrazy Neon | Plymouth Neon 3 08-18-2003 10:59 AM
