Old 12-21-2003, 04:48 PM
melon_medley melon_medley is offline
Replace Starter on 4.3l 4WD Blazer
I am replacing the starter on my 1995 Chevrolet Blazer 4.3l vortec 4WD, which I believe, should be a fairly easy job. I am using the Chilton manual and it mentions a special technique for 4WD versions.
* Unbolt the engine mounts, then raise and support the engine using a suitable lifting device.
* Unbolt the transmission mount and support the transmission assembly.
My thinking.... Right! Lift the engine to replace the starter!!
Well.... I had access to the starter bolts and proceeded to remove the unit and guess what? There is not enough room to completely remove it.
Unfortunately the Chilton manual is a bit vague on how to remove the engine mounts and lift it up.
Does anyone have any experience on replacing the starter. Perhaps some web page links.
Thanks
Jon
Old 12-21-2003, 07:39 PM
Jethro_Canada Jethro_Canada is offline
Re: Replace Starter on 4.3l 4WD Blazer
I'm not sure about this, but don't you have loosen the Y pipe to get enough room to side the Starter out?
Old 08-03-2004, 04:29 AM
pingwin02 pingwin02 is offline
Send a message via AIM to pingwin02 Send a message via MSN to pingwin02 Send a message via Yahoo to pingwin02
starter tips
I have a 97 blazer and I replaced the starter without loosening anything or lifitng the engine. From what I learned the trick is to un bolt it first then take the wires off and jiggle it out. Then when replacing it connect the wires first then bolt it in. It is a snug fit though. when you unbolt it pull it out and hten up and then down. Hope it helps a little.
Old 08-03-2004, 01:05 PM
bobmga62 bobmga62 is offline
Hi..
I replaced the starter on my 96 blazer, and yes it was a very tight fit... it gave me fits almost...I did it probably within the first two years of the car.. they would not warranty it.. because, you guessed it, every time I went to the dealer it would work.. uponpulling the starter out, I found a hair line crack in the solenoid that would short occasionally...
The one problem I had, was the igintion hot lines was so short, that I cut, and soldered on an additional length of about 6 inches, so that i could attach it to the starter and still get complete movement of the starter.. it was tight though...
Good luck
R
Old 08-06-2004, 12:47 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Mine came off without any mount removal.
Old 12-16-2004, 10:20 PM
ibck42 ibck42 is offline
Send a message via Yahoo to ibck42
my 95 blazer has same prb
WEll i tried to remove my starter from the exact same model Melon_melody and yep there is not enough space to drop down the starter.. i removed the metal cover from the solinoid as i was told this by the Chevy dealer as the reason it would not come out easy. nope same problem.. when you push back the starter from its housing it is aproximatly 1/4 inch to long to drop down.. and the back of the stater hits on a metal plate welded to the frame that keeps it from dropping down. what a stupid design flaw.. how could they have guts enough to make it that you have to jack the dang engine up to remove a starter???? arrrrrrrrrrrrrrrrrggg.. sure did a great job on making you take the dang thing to a dealer!!!!.. sure has me wanting to get away from Chevy!! back to Ford!
Old 12-17-2004, 03:35 AM
SlammedClipse SlammedClipse is offline
Send a message via Yahoo to SlammedClipse
Go back to ford cause you can't get to the starter???
Old 12-17-2004, 12:47 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Replace Starter on 4.3l 4WD Blazer
Buy an Exploder and you will find out just how insignificant your problem really is.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-17-2004, 01:59 PM
Thumbs up Re: Re: Re: Replace Starter on 4.3l 4WD Blazer
This man speaks the truth...
1997 Chevy Blazer LS(Nothing Done Yet)
2001 Dodge Durango(Nothing Done Yet)
2003 Mitsubishi Eclipse GS Sporty
-Injen Cyborg Cold Air Intake
-Z1 Racing Chip
-Ripp Mods SDS
-AEM Cam Gears
-Greddy Evo2 Exhaust
-Enkei 18" Rims
-Tanabe Lowering Springs
-Stinger Alternator
-Ripp Mods Header
