Old 12-11-2011, 09:46 PM
7T9Shark 7T9Shark is offline
Need to replace 96 Blazer brake line!
The brake line going from the ABS to the rear driver's side rear wheels on my '96 Blazer rusted through. Looking at it on my back in the garage, it looks like a job needing a floor hoist.
Has anyone out there done this, and what are the steps? It looks very crowded between the frame and body.
By the preponderance of similar posts out there, I'm not the first one who's experienced this phenomena.
Old 12-12-2011, 08:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Need to replace 96 Blazer brake line!
Well a hoist does help but it can be done by jacking it and putting it on jack stands.
You may have more than one bad line.
Do a carefull look over at the other line while you are at it.
Also the lines may be metric bubble flare lines with diffrent fitting on each end.
Remove each end of line and match up with a replacement line.
Most parts places have steel brake lines and or adapter fittings to do the job.
Good luck and let us know how it goes.
MT
Replacing Leaking Brake Line & Bleeding System! 1995VaFordCrownVic Crown Victoria 1 11-27-2007 09:33 PM
need to replace front brake pads on 2001 cavalier need help oceangal4you Cavalier Problem Diagnosis 1 06-23-2007 08:39 PM
89 S10 Blazer 4x4 4.3L Need rear driverside brake line. phil78 Problem Diagnosis 1 01-29-2007 08:35 PM
