Old 12-08-2011, 08:02 AM
JIMBOBX4 JIMBOBX4 is offline
Brake Warning Light /ABS Module
I have had my 2000 Ford Taurus in the shop three times now for an intermittent brake warning dashboard light. This is the red brake light, not the ABS light. After they replaced the master cylinder and sensor (fluid sensor they said), the light still comes on. The most recent diagnosis is that this is being caused by the ABS module and it will cost $900 for a new module. Does this sound right? Does this mean my ABS is not working?
Old 12-08-2011, 01:31 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Brake Warning Light /ABS Module
If you're not getting an ABS warning indication, I would be VERY hesitant to replace the ABS module. Has anyone confirmed that the parking brake is fully released and that the switch is working properly? The source of the red Brake light coming on is a pretty simple circuit typically and should not be too difficult to correctly diagnose.
-Rod
Old 12-08-2011, 10:20 PM
shorod's Avatar
SHO No Mo
According to the factory service manual, the Brake light is strictly to indicate either a low fluid level or that the parking brake is engaged. The light is driven by the Generic Electronic Module (GEM).
-Rod
The Following User Says Thank You to shorod For This Useful Post:
JIMBOBX4 (12-11-2011)
Old 12-11-2011, 06:56 AM
I engaged/disengaged the parking brake before I took it into the shop but that did not clear the light. However, maybe the switch is defective. I will try that route before doing anything else.
Thanks for looking it up in the service manual.
Old 04-14-2012, 03:00 PM
Tinovolpe Tinovolpe is offline
I had the exact same problem I tried everything and came tO the conclusion my abs is shot. In my case when I start the car the abs light and traction control light don't flash on and the brake scan tool doesn't get any signal from the abs module. My lights been on for over a year. Don't know if it is worth the money on my 11 year old car
2003 4runner brake warning light glows dimly. 4Runner03 4Runner/GX470 2 11-13-2011 01:08 AM
Brake Warning Lights? Traction Off Light? ABS Light? krivasauto Intrigue 1 12-12-2009 10:17 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 09:49 AM
93 regal ABS/BRAKE warning light + alternator "gauges" light noclues Regal 3 12-29-2007 04:32 PM
abs light is on and brake warning light in flashing? johnsoms Beetle - New/New Beetle Convertible 2 04-08-2007 07:11 PM
