Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-08-2011, 12:25 AM   #1
Motojojo
brakes make mechanical whine noise
when i press my brakes at low speeds there is a mechanical whine that i can hear and it seems my abs is turning on as if it thinks my car is about to slide if the car is shut off then restarted the abs light will usually come on and the whineing noise will not happen no brake work has been done to car resently car is a 93 lumina
Motojojo is offline   Reply With Quote
Old 12-08-2011, 07:51 AM   #2
Tech II
Re: brakes make mechanical whine noise
If the ABS light comes on and the noise is gone, it's because the ABS system is disabled......need to get the ABS code read....
Tech II is offline   Reply With Quote
Old 12-08-2011, 12:41 PM   #3
Schurkey
I guess that's about to change.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Schurkey is offline   Reply With Quote
The Following User Says Thank You to Schurkey For This Useful Post:
Motojojo (12-08-2011)
Old 12-08-2011, 01:48 PM   #4
Motojojo
but i can only get the codes when the light is on right?
Old 12-08-2011, 03:46 PM   #5
McLin
McLin's Avatar
I have the same problem. My ABS is not working since 4 years ago. Sometimes it is cold the abs turns on, but I have clicking sound on break pedal. Now we have, if ABS turns on the whining noise too. All peoples look at us. But if the ABS turn off then all is fine.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
McLin is offline   Reply With Quote
Old 12-08-2011, 05:20 PM   #6
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Sounds like the ABS accumulator pump is running inappropriately. Accumulator might be blown or something, valve stuck, whatever. Hard to say. Will have to be code scanned for an answer.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 12-08-2011, 05:32 PM   #7
gmtech1
gmtech1's Avatar
If the light came on, there should be a code stored.
gmtech1 is offline   Reply With Quote
88 caravan making whining noise Anna B Caravan | Voyager 4 11-29-2007 05:14 PM
Brakes making a squeaking noise Ducaire S-10 6 10-31-2005 05:39 PM
94 RS 4 cyl. engine making whining noise jcs290 Cavalier 5 09-10-2005 05:02 PM
Silverado makes a whining noise stevo226 C/K 4 04-19-2004 04:25 AM
