94 RS 4 cyl. engine making whining noise
I have a '94 Cavalier RS 4 cyl. Just recently, the engine is making a whining noise that gets louder and higher pitched as the RPMs increase. I took the car in shortly after discovering the noice for an oil change and had the mechanic inspect the belts and fluid levels for the power steering, brakes, and coolant. They found no problems and the oil change itself didn't affect the noise either.
I've seen that others with similar problems have complained of bad EGR valves, or that the noise is "pleasant" and means the engine is running optimally. My EGR valve was replaced last month for the car's annual inspection. Also, I find it hard to believe that any noise coming from a 146000 mi. engine is a good sign. Any ideas for what this could be? Is it a harmless issue or is it something more internal in the engine like a loose cam shaft? Any help would be great. Thanks! |
Re: 94 RS 4 cyl. engine making whining noise
I think this is on the right track. If the noise is related to engine speed ONLY then I would look at the tensioner bearings, Alt bearings, etc.. This is much more likely than whatever you mean by "a loose cam" Good Luck.
![]() Yes, I am retarded. |
To Mr Public
Hi Mr. Public, I try to email you but with no luck. I found one post you did talking about your changing comp/drier on your own car. I'll do silimar things and want get your help on some questions.
Thanks in advance. jeffjohn |
Re: To Mr Public
Sure, My email is [email protected] I won't be in the office until next Friday so you may want to post your questions for a faster response.
Hi Don,
Thank you! I'll work on my car next weekend, so I'll email you my questions. Thank again. |
