Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 12-06-2011, 07:16 PM
dan fitz dan fitz is offline
Angry 95 E250 alternator
just took out the alternator on my 95 van with a 4.9L straight 6, man was it a b****! my haynes manual said to loosen the fan shroud but it probably should just come all the way off. i ended up cutting the corner out for clearance and yes, i poked a hole in the radiator. even with the plastic out of the way i had to pry it out. needed a new radiator anyway, the old brass one had a number of weep holes up top that i've soldered over the years. i got new brushes and a new regulator over the counter from my local auto electric shop for about $13 instead of $65 at autozone. brushes were worn down to their ends, i think this was the original which if so went over 200K, hard to believe but... i'm going to open it up, clean up the slip rings and try to lube the bearings while i'm at it, since the $180 i would have put into the alternator is going to the radiator instead. and i'll put it back in while the radiator is out!
E250 Wild Growl Above 45mph wda0025 Commercial Trucks 6 01-25-2008 11:38 PM
1996 Alternator alternatives? MdPhoenix Rodeo | Passport | MU 3 09-16-2005 02:51 PM
No power on E250 OBDII Port akirson Econoline 2 01-27-2005 05:22 PM
1995 E250 Rear Springs RHawk221970 Econoline 2 10-30-2004 05:46 PM
95 E250 Leaf springs RHawk221970 Econoline 0 05-23-2004 08:19 AM
