Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 11-29-2004, 01:43 PM
akirson akirson is offline
Question No power on E250 OBDII Port
2003 Econoline E250 - I don't seem to have +12VDC on the OBDII port. Does anyone know if there's a fuse on this line, and if so, which one is it? Is it on the fuse block under the dash to the left of the steering column?
The vehicle runs fine, so it's probably not the ECM, and it's quite new (42,000 miles).
Any help will be greatly appreciated.
Old 01-27-2005, 02:27 PM
Hoser1369 Hoser1369 is offline
Send a message via AIM to Hoser1369 Send a message via MSN to Hoser1369 Send a message via Yahoo to Hoser1369
Same prob
I have a 200 E-150 that does not power the scanner. If I figure out what the fix is I will let you know. Or if you do let me know.
Old 01-27-2005, 05:22 PM
Re: Same prob
Hoser, we took the vehicle into the Ford dealership - turned out to be a blown fuse. Unfortunately, I wasn't present at the repair, so I can't tell you which fuse or where it is. Sorry.
