Old 12-06-2011, 03:32 PM
dagan06 dagan06 is offline
Smelling antifreeze
I have a 2001 and I started smelling antifreeze today. If I'm driving I don't smell it unless I am stopped at a stop light or stop sign. It seems to be stronger when I am outside the van. I know when you smell it inside it is usually the heater core.
Old 12-06-2011, 04:35 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Smelling antifreeze
Such a pleasant smell isn't it.....
If you can smell it, then it's escaping from some where.
Can you get under the van with a torch and see where it's coming from?
Old 12-06-2011, 05:29 PM
wiswind wiswind is offline
Torch = flashlight in the USA.
Moppie is not advising that you go under your vehicle with an open flame.
Have you needed to add any coolant?
As advised, look around under the hood for any signs of coolant leakage.....it should leave light colored deposits when it dries.
Likely locations for leaks would be a split in the seam on the radiator overflow bottle, loose hose clamp......so leakage at the end of a hose, That crossover pipe that goes through the lower intake manifold, the water pump....near where the pulley shaft goes into the pump.....ususally a small hole there, Front cover.....aka timing cover...which is the cover that the water pump and oil pump mount on, lower intake manifold gaskets......or around the radiator.
You can still smell coolant from a leak under the hood.
Let's hope that it is a easy and cheap solution....heater core is a pain to change as is the timing cover.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 12-06-2011, 05:56 PM
Well I found where the leak is. There is a hose under that runs under the intake and it is leaking. Anyone know what it may be called?
Old 12-06-2011, 08:21 PM
tempfixit tempfixit is offline
8548
(KM-4386)
Engine Coolant By-Pass Hose
3.8L; Mounts to rear of intake manifold with bolt. includes rubber hose to 18663 waterpump tube; Includes o-ring 391356-S100
$62.
Engine by pass hose
Video on the fix
part 1 http://www.youtube.com/watch?v=AWomi-tfjoc
part 2 http://www.youtube.com/watch?v=46T9DTYeppM
The Following User Says Thank You to tempfixit For This Useful Post:
Moppie (12-06-2011)
Old 12-07-2011, 09:52 AM
tomj76 tomj76 is offline
FYI, the fitting at the end that hose on my '96 is a quick-connect plastic type. Over time the plastic becomes brittle, cracks, and a "slow leak" emerges. Eventually it fails catestrophically (mine did), so if your leak is coming from that it's best to attend to it NOW. The fitting can be replaced without replacing the entire hose assembly. Alternatively, I've been told that the hose can be clamped to the nipple on the manifold with a normal hose clamp.
Old 12-07-2011, 10:08 AM
Mine is rubber and metal no plastic. I am wondering if I could have it soldered instead of replacing it.
Old 12-10-2011, 01:12 PM
Replace is better than solder.
You have to take that part off anyhow and it could have other rusted spots ready to fail.
A replacement pipe should last at least another 5 years (worse case), so you will not have to worry about it again.
1996 3.8L Windstar
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 12:19 PM
Help Im clueless, I smell antifreeze bluegrassbaby81 Lumina 2 10-20-2005 06:24 PM
Smelling Antifreeze KimmyBarr Grand Prix 5 01-31-2005 06:56 PM
smell antifreeze tkhilliard Grand Prix 8 01-12-2005 05:13 PM
i smell antifreeze bcampbell Grand Prix 14 11-26-2004 10:49 AM
