Old 12-05-2011, 03:12 PM
grandam11 grandam11 is offline
low fuel,won't start
Hi every-one,
I have a 2000 Grand-am,and when the fuel gets to a quarter tank or below it seems like the fuel pump won't pick-up and start the car (only if left overnight).I can then put 5-7 litres of fuel in and it will start.From other threads it sounds like it might be the pump.Any-one have any ideas.Thanks.
Old 12-06-2011, 08:42 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: low fuel,won't start
Welcome to AF!!
There are a couple of possibilities. First, consider that the gauge is wrong and that the light is coming on when the fuel tank is actually empty especially if you add fuel and the car starts. Second, if the car is positioned where the fuel pump is not in contact with the fuel it will not pick up the gas and will not start. Finally. it is possible that the pump is not at the lowest point in the tank and will not pick up the remaining fuel when the light comes on. Not much you can do with any of the above other than keep more fuel in the tank.
The Following User Says Thank You to GTP Dad For This Useful Post:
grandam11 (12-06-2011)
Old 12-06-2011, 01:13 PM
Tech II Tech II is offline
You shouldn't let the fuel get that low anyways......that pump runs hot......need to keep it covered with fuel, to keep it cool.....it will lengthen the life of your pump, if not damaged by now....
Old 12-10-2011, 12:06 AM
It appears the problem is solved.Replaced the fuel pump and all is well.Now i just need to convince the wife not to let the tank get so low. Ya right
Old 12-10-2011, 09:08 AM
Sag, should post your own thread in the Buick section....
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 03:39 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
82 Camaro won't start kelshm F-Body Problem Diagnosis 3 03-09-2009 08:22 AM
325i low battery won't start w/ jump LFL Technical 1 09-19-2006 04:24 PM
not getting fuel, won't start sixpack_cuda Fiero 1 08-21-2004 11:56 AM
